Old 04-28-2015, 05:19 PM
Juiced190's Avatar
Juiced190 Juiced190 is offline
Boat: 04 X7
Is this a good amp or should I go another direction?
Is the Clarion marine APX 480m a good amp for $100 or should I go newer? Thanks
Old 04-28-2015, 05:32 PM
wilhelmwake's Avatar
wilhelmwake wilhelmwake is offline
Boat: 2017 X23 Ilmor 6000GDI RadNorth Edition
What are you planning to use it for? The answer depends a lot on that....
-=MasterCraft All The Way=-
2017 MasterCraft X23
2015 MasterCraft X23
2007 MasterCraft X45
2009 Malibu WAKESETTER VLX SS
2005 MasterCraft X-Star
2004 Tige 20v
1995 MasterCraft ProStar 190
Old 04-28-2015, 05:36 PM
Juiced190's Avatar
Boat: 04 X7
I'm audio illiterate, so I'm not really sure was thinking about powering some tower speakers.
Old 04-28-2015, 05:40 PM
east tx skier's Avatar
MC Hero
Boat: 1998 Ski Nautique
What is the RMS power rating of your speakers vs. the RMS power rating of the amp?
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 04-28-2015, 05:43 PM
Juiced190's Avatar
Boat: 04 X7
I haven't bought speakers yet. I saw the amp on craigslist and it looked like a good buy, obviously I have a lot to learn.
Old 04-28-2015, 05:56 PM
MC Hero
I don't know much, but when I have done my shopping, I try to consider what the speakers I have want and what the amp can produce. That's RMS power per channel, not peak power (think of RMS power as constant power). I try to get an amp that can produce just about what the speakers want. I have a 5 channel car amp in my closed bow that has been doing just what I wanted it to do for the past eight years with no issues.
Again, I must stress my lack of expertise on the subject. On the other hand, I installed it, it sounds good to my somewhat picky ears, and has held up well.
So the specs for this amp are as follows:
80W 4 Into 4 Ohms, 20Hz-20kHz @ .05%THD
115W 4 Into 2 Ohms, 20Hz-20kHz @ .2%THD
Variable Bass Extender, 0-15dB @ 45Hz
Adjustable -12db/Oct. High/Low Pass Crossover, 55Hz-550Hz
So you want to look at the resistance (ohms) of whatever speakers you're considering and the RMS power rating to see if this amp looks like it's a good fit.
FAQ
Be kind. Have fun.
Old 04-28-2015, 06:30 PM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
That's an old amp. FWIW, I sold the stock one out of my 2003 X-2 for $50 a couple of months ago.
Old 04-28-2015, 07:32 PM
Juiced190's Avatar
Boat: 04 X7
Thanks everyone, I appreciate all the replies. I think I'll do a little more research before I drop hundred dollars on something that may not be the right fit.
Old 04-29-2015, 09:53 AM
bsloop bsloop is offline
Boat: 91' MC 240sc
When buying a new system, start with your speakers, then work backward amps, head unit, wiring, batteries.
If you start in the middle, chances are you are going to end up with wasted components = wasted money and time. A novice especially will buy too small.
Old 04-29-2015, 02:07 PM
mseller mseller is offline
Boat: 2008 X45
agree with bsloop.
most speakers can handle more power than what they are rated for too. just gotta adjust the gains properly.
amp, speakers, stereo
