Old 05-02-2018, 12:46 AM
G60Gates G60Gates is offline
Boat: 1993 mastercraft stars & stripes 19 ft.
Smile 351w Head replacement
I have a 1993 19ft, stars & stripes edition boat. The motor is stock. One of the heads has a small crack in it which leaks water, not bad but constant. I bought the boat a few months ago knowing this. The previous owner said he has put JB weld on it cow 2 years and ran it. So I have a st of fresh gt 40 heads available, real cheap, so 1) will they fit, 2) what 4 bbl. intake to run, 3) will the water log exhaust work, 4) without a cam change, is it worth it, and finally 5) should I just replace the stock heads. The boat is near perfect except the crack in the head. Thanks.
Old 05-02-2018, 01:06 AM
1. If they are the GT-40 heads they will bolt right on. If they are GT-40P heads, you will need to drill he head bolt holes to 1/2Ē.
Most popular intake is the
2. Edelbrock Performer intake.
3. Exhaust manifolds will fit.
4. There will be gains in HP with just the heads, more if you add a cam (though this can diminish drivability), more gains if you increase compression by shaving the heads (removing material from the bottom of the head to make the combustion chamber smaller, more gains if you rebuild the engine and stroke it to 427 cubic inches.... Itís a matter of where to stop. Hours on the engine make a difference. If you have a lot of hours and change the heads and cam, you ought to consider a rebuild.
5. As you need to change heads, there is no reason not to go with the GT-40 heads unless itís a budget related thing.
Another thing to consider is your carburetor. Are you still running the Holley 4010 or have you switched to a Holley 4160?
Electronic ignition?
Old 05-03-2018, 06:41 PM
david_ski david_ski is offline
Boat: 2003 SN196, PCM 330HP 5.7L, ZeroOff
What he said. Bolts right in.
I replaced my GT-40's (water jacket crack) with new GT-40P's (I drilled out the 1/2" bolt holes myself because engine shop forgot to).
Edelbrock Performer definitely improves HP.
Don't skip on painting it. A friend added the aluminum intake and he did not paint it. BIG mistake.
Night and Day difference between the Holley 4010 and 4160 (runs consistent hot & cold, at speed and idle).
Previous: 1993 ProStar 351HO
Old 05-03-2018, 06:51 PM
03 35th Anniversary's Avatar
03 35th Anniversary 03 35th Anniversary is offline
Boat: Searching
Why would you paint Aluminum Parts??? It defeats the purpose of using Aluminum Parts...
Old 05-03-2018, 06:53 PM
Unpainted..... my preference...Nothing BIG about paint one way or the other.
I like the Edelbrock OEM contrast.
John 14:6
Old 05-03-2018, 10:31 PM
If you want the bare aluminum look, but not the hassle of keeping it looking clean, use a high heat clear coat prior to installation.
Old 05-04-2018, 07:06 AM
Boat: Searching
Coating aluminum parts with anything hinders their ability to expel heat. Not that it would be a big deal either way in this application.
Old 05-04-2018, 09:23 AM
Agreed on both counts.
