Old 11-14-2018, 04:56 PM
Bartnich Bartnich is offline
Boat: 1995 Prostar 205 5.7L
What Sayeth the Collective- Gelcoat
So I'm debating whether or not to fix this gelcoat on the bow. Its not a structural issue, purely cosmetic. While it would be nice to fix it, I don't want to actually make it look worse than it does right now as I think matching the gelcoat might be difficult and it is not highly obvious right now. I saw a list of color matches on another thread somewhere and didn't see anything that sounded particularly close to what the color is- sort of an off-white. It's a 1995 Prostar 205.
Any thoughts or suggestions?
Thanks!
Old 11-14-2018, 05:11 PM
MC25's Avatar
MC25 MC25 is offline
Boat: 2016 X30, 85 S&S
-10 MCOCD points for having to ask
-Aric
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
Old 11-14-2018, 05:12 PM
That's not helpful.....
Old 11-14-2018, 05:16 PM
Let it ride like it is. Your call but one can of worms will lead to another (not necessarily in a bad way).
One of the costs for these type repairs is the time (x cost per hour) to mix and match. I know you have implied you would do the work. Just takes time and patience to match (not difficult, just tedious), then the prep, then the finish.
But if it really bugs you....
$0.02
John 14:6
Old 11-14-2018, 05:21 PM
$0.02
Yes, that is my fear. I've got a two year old with a bad attitude, so time is not something I have a lot of right now... The color match is my biggest concern I think.
Old 11-14-2018, 05:26 PM
Originally Posted by Bartnich View Post
Yes, that is my fear. I've got a two year old with a bad attitude, so time is not something I have a lot of right now...… The color match is my biggest concern I think.
I use a white and then a gray color sample to blend and match the pigment. When you get it right from mixing, then use that mixture for further application.
I would not cut out a lot on the cracks. Just open them up a little and bevel or smooth the edges then fill in.
Remember that you will want to sand and blend a ways out to get it back to a smooth finish / transition. So tape it off accordingly.
John 14:6
Old 11-14-2018, 06:01 PM
swc5150's Avatar
swc5150 swc5150 is offline
Boat: 2015 Prostar
'95 white was called "oyster", if that helps?
Old 11-14-2018, 06:13 PM
neil.anderson63's Avatar
Boat: 2007 X2
It's winter, fix it. Especially if you're garage'd. I would rather have a slight color variation than the cracks.
Wifey had a little mishap with the dock on our X2 and nicked one of the pickles. I worked it for a couple nights through the week and have a very slight color variation. Take your time and repair it.
Old 11-14-2018, 06:51 PM
tr6coug's Avatar
tr6coug tr6coug is offline
Boat: Mastercraft 2007 X2 MCX
That would bug the hell out of me if it were my boat. I vote "fix it".
'07 Navy Blue X2 MCX
http://www.wakeblaster.com/
Old 11-14-2018, 07:22 PM
If you have the time fix it. US composites has a color system to mix custom gel coat. Good thing about gel, it doesnt change color when curing... or you can get a gel coat repair kit.. get the color right before you bring out the dremel.. or get a sticker/decal made to cover it... personally more hassle than its worth.. its not flaking off.
