Old 08-15-2018, 05:02 PM
jimboj's Avatar
jimboj jimboj is offline
Boat: 2008 Mastercraft X15, 1997 Prostar LT1
For giggles I did a quick little test. At 15 foot from the back of the boat, with no sound except normal outdoor sounds, decibel level was 42. Used aux and sent a 1 KHz signal into head unit and volume set at 25. At same spot behind boat the level was 82.8db. Sent same signal directly into amp, and at same spot behind boat the level was 93.1.
This was with Non Fade setting at 6, which I don’t know where this setting was before the issue started.
I have another head unit that I may try if I can find the connector that goes into the back of it, but that might mean all the input levels will have to be changed on the amps for the new unit. Any other suggestions?
