Old 12-11-2014, 04:29 PM
CheeseSteak1's Avatar
CheeseSteak1 CheeseSteak1 is offline
Boat: 2009 X30 MCX / 2003 X2 MCX
$7 Prop Puller
I know a few people have posted different ways to make a prop puller on other forums, but I couldn't find anything on TT. $6 for 4" c-clamp which I had and and $1 for 1" black iron pipe cap from Menards. I'm by no means a welder by trade so please be gentle. Worked like a champ and I have about 45 min into the project.
Tools
hand grinder with metal cutoff wheel, bench grinder, dremel tool & welder
How to
1) Make a templet with a piece of cardboard. Indicate the spacing behind strut to prop, front and back of prop and ruder to end of drive shaft
2) Use template to determine where to cut c-clamp end and attach cap (use c clamp worm gear to assist with alignment by tightening it all the way down)
3) Cut cap and shape before welding it on ( be sure it fits around shaft and dremel down the threads)
4) Weld modified cap on
5) Cut handle off worm gear and grind down two sides for a crescent wrench to bite
6) Cut worm gear to length and grind tip to a fine point
By no means am I cheap, but I can't bring myself to spend $120 for a glorified c-clamp. Feel free to hit me up for more info
Old 12-11-2014, 06:53 PM
JayBrown JayBrown is offline
Boat: 1976 master craft stars and stripes
Nice looks good
Old 12-12-2014, 12:02 AM
looks good - not bad if you have a welder.. sell them for $25 shipped usps priority small box?
Old 12-12-2014, 05:19 AM
byronic's Avatar
byronic byronic is offline
Boat: 86 19' skier 351 PCM
Nice job CS!
Old 12-12-2014, 07:08 AM
CruisinGA's Avatar
Boat: '01 X9 330HP
Have you tried it?
Bailey
'02 X-9
Lake Blue Ridge
Old 12-12-2014, 08:17 AM
76S&S's Avatar
76S&S 76S&S is online now
Boat: 2002 X Star
I made one very similar. I've used it a couple of times with no issues.
2002 X Star
Sold - 76 S&S
Old 12-12-2014, 10:20 AM
If I only had the time
Old 12-12-2014, 10:56 AM
Originally Posted by CruisinGA View Post
Have you tried it?
Yes, it worked very well. However, I may weld another black iron cap to the end of the worm gear to fit over the drive shaft to keep pressure centered. The end of my drive shaft does not have a recessed/cocaved center, which caused the pointed end of the worm gear to spin off center a bit while tightening. Hope that makes sense. Btw. I'm calling the threaded rod on the c-clamp a worm gear for lack of better term.
