Old 03-19-2013, 11:12 AM
CruisinGA's Avatar
Boat: '01 X9 330HP
Add-on Bluetooth
My '01 X9 has a CMD1 Clarion headunit, coupla amps, some ok tower speakers.
The stereo is fine for my purposes, just wish I had a way to use iphones via bluetooth.
I did the home-built method to add an auxiliary input to the CMD1.
What I am looking for is a device that will use bluetooth to connect to my iphone, and connect to the headunit using the auxiliary inputs.
I don't really want to install a new headunit, but I may consider it if what I am looking to do is a little heavy on the turd polish.
Bailey
'02 X-9
Lake Blue Ridge
Old 03-19-2013, 11:35 AM
mzimme's Avatar
mzimme mzimme is offline
Boat: 2006 20' Vdrive
Here's one:
http://www.amazon.com/BlueGate-Bluet...tooth+receiver
If you don't like that one, just search Amazon for "Bluetooth receiver". There will be an entire list. Some you'd have to add a power inverter... others charge via USB. Check out some reviews and take your pick!
-Mike
Old 03-19-2013, 11:45 AM
carlsonwa's Avatar
Boat: 2006 Prostar 197 TT
http://www.amazon.com/iSimple-ISFM21...mple+bluetooth
I have one of these hooked up to my AUX in on my alpine stereo.
Works great, since it either has the ability to hook up through the antenna or RCA outputs as well.
It automatically reconnects if you hook it to ignition. I hooked it on constant so it doesnt lose connection each time you cycle the key.
Only audio streaming for my iphone, no handsfree capability.
Old 03-19-2013, 01:51 PM
CruisinGA's Avatar
Boat: '01 X9 330HP
Ordered the iSimple ISFM21, it looks like exactly what I need. Thanks!
Bailey
'02 X-9
Lake Blue Ridge
Old 03-19-2013, 02:30 PM
pap pap is offline
I ordered this:
http://www.amazon.com/dp/B004CLYJ2I/..._M3T1_ST1_dp_1
Old 03-19-2013, 02:32 PM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
I've been using one of these in the boat for the last year. I also have one in the truck. They work great.
http://www.monoprice.com/products/pr...seq=1&format=2
Old 03-19-2013, 03:15 PM
Dylan's Avatar
Dylan Dylan is offline
Boat: Yamaha 212
Looks great. Would the audio quality be less with bluetooth? I'd love to know, as it is always a PITA to be on a leash with the stereo we have.
Thanks!
Old 03-19-2013, 04:45 PM
mzimme's Avatar
Thanks!
Technically yes the quality will be lower than a wire, but the casual listener probably would never know unless you had horrible quality mp3's, and then everything sounds bad. I'm sure Earmark marine could give you a better explanation there.
-Mike
Old 03-19-2013, 05:01 PM
JRW160's Avatar
Boat: 2003 X2
I play music from my phone, and I can't tell the difference between the audio quality over bluetooth and with a wirex aux cable connection.
Old 03-19-2013, 10:28 PM
KahunaCraft's Avatar
Boat: 2012 X30, 6L
Try playing some Clapton or acoustic song you like at a moderate clear volume. See if you can notice subtle differences in the quality of the sound at the same volume between the two types of sources of audio(wired vs BT ). Note that poor cables can have a difference too.
