Old 03-29-2016, 02:13 PM
Old boat owner Old boat owner is offline
Boat: Tristar 190 1987, Ford 351
Reupholstery foam - 1987 Tristar 190
Iím in the middle of a complete restoration of an open bow 1987 Tristar 190. Iím doing the re-upholstery myself. When I inherited the boat, the bow cushion was MIA. We cut a base out of marine ply, threw some Joanne ďMarineĒ foam over it and covered it with marine vinyl. Being inexperienced with marine upholstery at the time, we did not drill a drain hole or use underlayment to keep the wood off the fiberglass. It was a mess.
Being a Tristar, the bow is always wet, and after a change of location, it gets covered while itís still wet. The replacement cushion will be Dry-Fast foam, over a marine ply base with drain holes and slightly canted to drain toward the back. I canít figure out if I should glue the foam to the base. I am concerned it will block the drainage.
Also, how much does Dry-Fast foam compress?
Any suggestions for sources of reasonable Dry-Fast foam would be appreciated.
foam, tristar 190, upholstery
