Old 07-05-2012, 11:13 AM
PeterK PeterK is offline
Boat: 2007 X2
X2 Surfing
Looking for advice regarding the trim tab(s) for surfing with my 07' X2. I have a single center tab. Should this be up or down for surfing? Would it help to add separate P + S tabs on each side, as well? Otherwise, I seem to do well with factory ballasts, as well as a fat sac in back compartment on side of surfer. BTW, what does "KGB" ballast stand for? Thanks for any comments!
Old 07-05-2012, 12:06 PM
TheWoons TheWoons is offline
Boat: 2018 X23
Typically if the center tab is up the wake is steeper and shorter and as you put it down it gets longer and more shallow top to bottom. Most people put the center tab at 30-60 depending on weight and setup. Surf tabs do help make the wake longer. The more weight the better it'll be.
Ryan
www.DDWPartners.com
Porsches and toys and stuff....
Old 07-05-2012, 12:09 PM
MattsCraft's Avatar
See this post, everything on proper weighting set up should have you all set.
http://www.mastercraft.com/teamtalk/...t=48746&page=2
KGB stands for Keel-Line Gravity Ballast
Old 07-05-2012, 01:13 PM
BrooksfamX2's Avatar
Boat: 2007 X2
I run with mine (center tab) up. It is intended to flatten the wake for skiing..........
Will be adding the wakemakers piggyback 455lb bag to the port locker next week when it gets here.
MISS "B" HAVEN
2007 X2, Indmar 350 MCX (Sold)
OJ 522 14.75 x 15.5
Tugger: 2014 Ram 1500 Crew, EcoDiesel
http://www.crowniehq.net
Old 07-05-2012, 02:03 PM
Boat: 2007 X2
Thanks for everyone's response!...I'll be surfing tonight and plan to try adjusting the center tab!
surfing, trim tab
