Old 06-13-2016, 12:18 PM
MC Lovin MC Lovin is offline
Boat: 2007 Mastercraft X-Star
3000 RPM's Cutting out
First off I did search this, And seen a ton of info.
Here is what happened, I started the boat in pretty shallow sand beach. When i took off boat ran fine and then cut out and check engine light came on within a minute. Oil pressure and temp were the same as usual. After running at idle speed for 10 minutes I shut the boat off and restarted it and same issue.
Again, I turned the key off but this time I did a battery disconnect and restarted it and boat ran fine all the way home which is about a half hour ride.
Should i still be concerned? I'm thinking maybe I did suck some sand and it wasn't getting enough water and whatever was clogging it came out and the battery disconnect reset the computer per say.
Any thoughts are GREATLY appreciated!
