  #161
Old 07-10-2018, 02:15 AM
joelevy joelevy is offline
Boat: 2007 X45, 8.1L
@tr6coug (and others)
Here's my situation - 2007 x45. I had bakes marine in Seattle put in 2 extra sacs a year ago and they upgraded the controllers to the newer jabsco 18500 0520. I think they did this b/c these can be programmed for longer than the factory? Not sure exactly why in hindsight. I still have the factory original controllers as well.
I now have a situation where my starboard pump will fill but not empty. It's not the pump / impeller - I can plug it into the middle controller and it will empty fine. I also changed the wiring to another switch and that didn't help. I called Jabsco and they are pretty sure it's the controller.
So my situation, I think, is I can replace the newer controller (Jabsco will replace for free) or just have tr6coug reprogram the factor original controller.
Does this sound right? Any other tips for this situation?
Thanks!
Old 07-11-2018, 11:20 AM
tr6coug's Avatar
tr6coug tr6coug is offline
Boat: Mastercraft 2007 X2 MCX
If I reprogram the original one you can set it for any amount of time you need. Sounds like the new timer may be bad and if Jabsco will replace it then I would have them do that.
'07 Navy Blue X2 MCX
http://www.wakeblaster.com/
Ballast Timer Reprogramming Info
Old 07-16-2018, 03:38 PM
Yes. Jabsco timer was bad. They replaced and all fixed. Thanks!!!
Old 07-22-2018, 02:52 AM
Dave Kennedy Dave Kennedy is offline
Boat: X15 2009
I would very much like to reprogram my ballast timers. MY 2009 X15 has the wires crimped on. The portable programmer would be perfect. Is it available?
Old 07-22-2018, 03:22 AM
tr6coug's Avatar
Yes. Please PM me and we can arrange it.
Old 08-26-2018, 12:15 PM
Another thumbs up for tr6coug firmware on original ballast controllers. Timed switches work like a charm.
Old 09-14-2018, 12:13 AM
tr6coug's Avatar
Thanks Joelevy! Glad you are happy with your new firmware.
