Old 07-15-2018, 12:17 AM
Kevin_M's Avatar
Kevin_M Kevin_M is offline
Perfect pass wont stop timing / beeping?
Hi Friends, I have a 2003 PS 197 TT with the predator 310 engine. Since I bought it in 2007, the PP worked perfectly for all I use it for, locking in a consistent speed for skiing/wakeboading. Itís never run a course, and Ive never needed or used the timer.
Randomly last time out, it started beeping non stop, timing up to a few tenths of a second, beeping again, timer starts and counts up to a few tenths and repeats. Really annoying. When its on the trailer and I turn the key the system seems to boot up / act normal. As soon as I put it in the water and start the engine, this cycle of timing, beep, reset, timing, beep, reset continues, no matter what condition the PP is in.
Ive tried a reset of the system. Iíve tried unplugging the smart timer. Nothing seems to change this. Any ideas? Is the master module shot? I have no idea what to try next and really donít want to take to my local MC dealer unless I have to.
Thanks for any help!
File Type: mov 134056DA-C698-4333-941E-FAC0B8C171C2.MOV (35.46 MB, 22 views)
Old 07-15-2018, 06:28 AM
Boat: 93 190
Originally Posted by Kevin_M View Post
Hi Friends, I have a 2003 PS 197 TT with the predator 310 engine. Since I bought it in 2007, the PP worked perfectly for all I use it for, locking in a consistent speed for skiing/wakeboading. It’s never run a course, and Ive never needed or used the timer.
Ive tried a reset of the system. I’ve tried unplugging the smart timer. Nothing seems to change this. Any ideas? Is the master module shot? I have no idea what to try next and really don’t want to take to my local MC dealer unless I have to.
If you do not get this resolved here, call the folks at PP for additional guidance. They have excellent support service from all I have read on the forum. I have had to use them one time after the initial purchase and got excellent support.
John 14:6
Old 07-16-2018, 07:52 AM
slalomjunkie slalomjunkie is online now
Boat: NA
Agree - Call Mark @ PP. I have never seen anything like that. On another note, this could be a great time to upgrade to Stargazer.
The sea, once it casts it's spell, holds one in it's net of wonder forever - Jacques Cousteau
Old 07-16-2018, 08:35 AM
Boat: NA
You could solve your problems in 20 minutes with this for only $100, and it's an upgrade from what you have:
http://www.ski-it-again.com/php/skii...l&postid=47322
If you are hellbent on wakeboard pro - $75
http://www.ski-it-again.com/php/skii...l&postid=47284
Old 07-16-2018, 10:37 AM
88 PS190 88 PS190 is online now
Disconnect anything plugged into the timer ports and test again. NM see you disconnected smart time - my guess then would be that there is some sort of short on the board at the timer input.
I would atleast inspect the master module to see if there are signs of this being wet under the cover. The "on/off" trailer aspect makes me suggest moisture causing this - which you might be able to dry out.
Old 07-21-2018, 03:19 PM
Kevin_M's Avatar
Thanks everyone - that gives me a couple options for the next time I’m at the lake house. Stargazer looks awesome, but don’t think I’m ready yet to drop that kind of $ since I just bought the house. Slalomjunkie - that first link is gone, what was the upgrae you referenced? Can anyone confirm that if I had the digital pro master module originally, that a wakeboard pro module will work? Does it just not have the complexity of the timers?
I did leave the cover off one night when it rained...wonder if somehow water got somewhere it shouldn’t have...hmmm.
2003 ps197, perfect pass
