Old 11-07-2018, 02:22 PM
SS LS1's Avatar
SS LS1 SS LS1 is offline
Boat: '13 X2 Pro Gen2, '98 30th Anniv PS190- SOLD-
Shouldn't be a problem with a good welder.
2013 X2 Pro Pkg, Gen2 Surf
SOLD - 1998 30th Anniversary ProStar 190
Old 11-07-2018, 06:03 PM
waterbuffalo's Avatar
waterbuffalo waterbuffalo is online now
Boat: 1997 basstracker, 2000 Targa 210, 2007 mastercraft CSX..
Originally Posted by ccelia View Post
Bumping this thread - when winterizing this year, I noticed that my port side exhaust manifold is leaking from the bung where the 02 sensor is located. It is really hard to see any sort of crack, but I get slight bubbling so I can tell where it is leaking from.
My question is, can this be re-welded to stop the leak? Below is an example of the manifold that is on my boat. It is the ETX Cat Stainless Steel Manifold. I circled the area in question where the manifold is leaking from.
Any help would be greatly appreciated!
It you donít find anyone good to weld it, let me know. Iíve been welding 25 years and the last 16 doing SS manifolds for jet engines. Make sure they use purge gas ( on the back side ) it will help make the penetration clean so you donít get cracks reforming on the inside. Im in Michigan of you want to send it to me PM me and Iíll do it right.
Old 11-07-2018, 06:07 PM
ccelia's Avatar
ccelia ccelia is offline
Boat: 2009 Mastercraft X-45
Appreciate the responses!
Indmar has gone to a new design and I certainly didn't want to drop $3k on new manifolds if I can avoid it and get this one repaired.
Old 11-07-2018, 06:41 PM
Ya! .. donít spend that. We can do it a lot cheaper, if you donít find someone. See if you can find out what type of SS it is.
