  #281
Old 06-02-2018, 08:02 PM
horseshoept horseshoept is offline
Boat: 2003 Prostar 197, MCX, powerslot
Thank you Corey! Very happy with these. I was able to replace all three without removing the seat or the panel.
Old 06-14-2018, 11:41 AM
Flyfast Flyfast is offline
Boat: 2003 mastercraft x10
Corey,
If you’re still making the grommets, I’d Love to put an order in for a set of three for my 2003 x10.
I sent you a PM as well.
Thx
Derek
Old 06-19-2018, 01:58 PM
MCX006 MCX006 is offline
Boat: 2006 X-Star
I'm in need of these as well. PM sent to you Corey.
Old 06-23-2018, 11:58 AM
BellyUpFish BellyUpFish is offline
Boat: 2002 X-Star
I’m looking for one of the angled grommet that Corey no longer makes.
If anyone has one they wound up not using, please let me know.
Old 06-28-2018, 03:11 AM
TCUMasterCraft TCUMasterCraft is offline
Boat: 2003 MasterCraft X30
Corey do you still have any grommets? If so Id like to get 3 for a 2003 X30.
Old 06-28-2018, 01:35 PM
Covi's Avatar
Covi Covi is offline
Boat: 2008, PS 197, LY6
Send a message via AIM to Covi Send a message via Skype™ to Covi
After 2 years I finally installed mine. They are perfect. Great fix!
86' 19 Skier, 351 PCM (sold)
2008 197 ProStar, LY6
Old 06-29-2018, 02:00 AM
wheelerd's Avatar
wheelerd wheelerd is offline
Boat: 2005 X2
Just installed mine today . . . after getting them a year ago. Wasn't too hard -- here's what I did.
Preparation:
- Remove Captains seat. A 5-minute job -- four bolts requiring 1/2" socket and 1/4" Allen wrench
- Lift up the dash panel. A 1-minute job -- pop the 3 push pins next to the windshield and remove the two screws at the bottom beside the steering column. Doing this allows the side panel to slide out away from the hull.
- Remove the screw at the center bottom of the side panel.
- Remove the hidden Nylock nut up under the rear of the side panel.
- Remove the three Torx bolts at the top of the side panel. (T37 bit for the bolts and 7/16" wrench for the nuts)
Install:
- Start with top center bolt -- it's the hardest. Insert the new grommet and bolt.
- Lying under the helm I could just reach up and touch the back of the bolt with my left fingers.
- Place SS fender washer over bolt.
- Stick the Nylock nut to my duck-taped finger, reach up, and hold it to the stud while I reach around with my right arm and turn the bolt using a ratcheting stubby screwdriver until the nut catches.
- Then reach up with the 7/16" wrench to hold the nut and tighten the bolt.
- Front and rear grommets/bolts are easy
- Reinstall everything else
- Grab a brew, sit back and admire the finished work
Pic 1: grommets in place, and showing seat removed and dash lifted
Pic 2: important hidden stud/nut to remove
Pic 3: a trick I learned from an old mechanic dude when you are working blind and can barely reach a bolt
Old 08-05-2018, 05:15 PM
jrberardinelli jrberardinelli is offline
Boat: 2004 X-9
Hi,
Are these still available? Id love a set for my X-9!
Thanks
JR
Old 08-14-2018, 08:01 PM
geoff2664 geoff2664 is offline
Boat: Mastercraft, x10, 2005, 350
Any update on the availability of the armrest grommets?
