Old 03-22-2018, 11:24 AM
MJN MJN is offline
Boat: none
Battery maintenance
Hello. Just bought a 92 Ski Brendella (Shortline Comp), had it serviced including two new batteries - a starting and a deep cycle. I'd really like to make them last, so my question is during the summer if I'm taking it out several times/week, should I be charging them in between? with a trickle charger?
Thanks for any tips you can provide !
Old 03-22-2018, 11:40 AM
MC25's Avatar
MC25 MC25 is online now
Boat: 2016 X30, 85 S&S
I always put them on a the charger when I’m not using the boat. Battery tender or the promariner prosport charger.
-Aric
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
Old 03-22-2018, 12:45 PM
MLA MLA is offline
Boat: pontoon
Unlikely the main cranking would need charging between trips, but for house, depends on how its going to be used. If you will be spending long hours at anchor, then a short rid back to ramp/slip, then yes, it might benefit from an on-board charger between trips. For the off season, defenitely keep them on an on-board charger.
Old 03-22-2018, 12:58 PM
ValveCoverGasket's Avatar
ValveCoverGasket ValveCoverGasket is offline
Boat: '04 X9
it definitely wont hurt to have them on a trickle while not being used
ive had great luck with these on various cars that sit for long periods, and over the winter on our boat batteries
$20-30 on amazon and just set it and forget
Old 03-22-2018, 01:37 PM
Boat: 93 190
Trickle is a non-stop process. You'll get less out of your battery. Trickle is slow and chronic death when used as a primary source for battery maintenance. Your call.
I recommend and use exclusively the NOCO Genius battery maintainer with a micro-chip processor. With a dual setup, I separate the batteries with the control switch (off) and charge each battery with dedicated charger(s) each. It's plug and play and I never get in the boat after I get home to touch a battery. All right there on the shelf.
Amazon here
I also recommend the extension cord(s) if you are leaving the charger on the shelf (not onboard) and merely plug into the attached pigtail.
Each to their own....
$0.02
John 14:6
Old 03-25-2018, 09:16 AM
Scott62 Scott62 is offline
Boat: MasterCraft X25 2014 mv8
Battery Tender. My Optima boat batteries ($200 each) spend all winter connected. My John Deere mower battery is 14 years old. It is on a Tender always (other than when mowing). Best $50 you will spend.
Old 03-25-2018, 10:37 AM
Bwag1961's Avatar
Bwag1961 Bwag1961 is offline
Boat: 2014 Mastercraft X25 w/Gen2 and Surf Pkg.
Scott62...totally agree with you. I tender all my batteries and have noticed the extension of battery life.
Sent from my SM-G950U using Tapatalk
A boat is a hole in the water into which you pour money......but it's a lot of fun!!
Old 03-26-2018, 10:51 AM
cyclonecj's Avatar
cyclonecj cyclonecj is offline
Boat: 1984 Prostar
I have moved on to small solar chargers for my boat and jet skis. Trickle charge during the day, relax at night.
Harbor Freight has them under $15.
1984 Mastercraft Prostar S&S
Former Marine World ski show boat.
Old 03-26-2018, 12:49 PM
MJN MJN is offline
Boat: none
Thanks everyone - I ended up getting a battery maintainer from Harbor freight ($30). It charges until normal, then maintains it - just plug it in and leave it.
So far, so good.
