Old 07-21-2018, 03:58 AM
88falcon's Avatar
88falcon 88falcon is offline
Boat: 1988 centurion falcon
351 EI conversion
Hello
Quick question, I just ordered a pertronix ignitor 2 part number 91582 and a flamethrower coil for my 88 falcon ( I know not MC but this forum is the best).
Reading the instructions it says it recommends removing the ballast resistor.
Has anyone installed one of these ?
Is this neccessary?
It's easy enough to do but just wanted to make sure it's necessary before I remove it and splice the wires .
Thanks
Sent from my SM-G950U using Tapatalk
Old 07-21-2018, 01:32 PM
paco_06's Avatar
paco_06 paco_06 is offline
Boat: 1993 prostar 205 previous 85 S&S
Piece of cake to install as long as you have the right part. Just read the directions, ei plate should install one way for left hand engine and another for right hand rotation. And yes, use the flame thrower coil and bypass the resistor. All that needs to be fine for that is attach both wires on the same side of the resistor. You'll need to check timing after install. Whole job takes 15 minutes tops.
Sent from my XT1030 using Tapatalk
Old 07-21-2018, 02:48 PM
Originally Posted by 88falcon View Post
Hello
Is this neccessary?
Thanks
I have installed several. An easy fix.
You do not have to remove the resistor. I typically leave the resistor in place and use a jumper wire to jump the two posts together, serving the same objective. Your call.
John 14:6
Old 07-21-2018, 03:59 PM
88falcon's Avatar
Thanks much !
Old 07-21-2018, 04:00 PM
88falcon's Avatar
Yeah this is what I'll probably do , thanks for the response !
Old 07-22-2018, 02:31 PM
I have this ignition in my 77 S&S. Even simpler than a jumper wire across the ballast resistor is to put all the connections onto one post of the ballast resistor.
And donít forget to check the timing. It usually needs a tweak.
COSTOM DECALS - EMAIL FOR MORE INFO
Old 07-22-2018, 10:11 PM
alw65029 alw65029 is offline
Boat: Mastercraft, S&S, 1985, 351
As stated, just follow the easy directions. When looking at ballast resister at the rear of engine take the wire off the left side and move it to right side of resister making contact with power going into resister thereby eliminating the resister and completing the circuit without a resister.
Old 07-23-2018, 03:19 AM
88falcon's Avatar
Thank you Mrmastercraft . Which ballast resistor are they referring to ? The one located on the front of the motor near the coil ? Or the one on the back of the motor?
Old 07-23-2018, 07:36 AM
paco_06's Avatar
There should only be one resistor..... Rear of engine in the middle on top of intake near the starter solenoid. Distributor in front of carb and coil horizontal to the left of carb.
Old 07-23-2018, 10:11 AM
Should look like this with a purple wire going from it to the coil.
