Old 06-18-2015, 07:50 AM
bret's Avatar
bret bret is offline
Boat: Prostar 190, 1993, Anniversary Limited.
If cleaning the IAC, make sure you have a new gasket for it to avoid a vacuum leak.
Old 06-18-2015, 10:04 AM
Jorski Jorski is offline
Boat: 1993 190 with LT1
Also....check screen on the inlet side of the fuel pump...you have to remove the fittings to get at it....they just unscrew.
Old 06-18-2015, 11:15 AM
east tx skier's Avatar
MC Hero
Boat: 1998 Ski Nautique
Does it lope at idle? I had that issue on my boat (different engine). New IAC did the trick.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 06-20-2015, 07:45 PM
Dkattman Dkattman is offline
Boat: Mastercraft, Prostar 190, 1995, lt1
OK. I replaced the two fuel filters, removed the fuel pump on the back of the motor and found a clear screen, replaced the throttle position sensor and the IAC, and cleaned the intake and butterfly with choke cleaner without dismantling it. Started just fine. Idled well for 5-8 minutes. Then the motor started dying. Seamed to have a slight lag when juicing the throttle. The fuel pump whines off and on. Didn't feel comfortable taking it for a test drive.
In summary it started right away, idled fine for a while, then stumbled. My instinct is it isn't fixed and will continue to die.
Any help is appreciated.
fuel, gas, idle, ignition, lt1
