Old 04-27-2010, 11:52 PM
wannabe wannabe is offline
Boat: Mastercraft PS 205, 2000, 330HP
Exhaust leak
I have a pinhole leak in my 2000 PS 205 Silent Master (exhaust). Looking for advice: patch or repair, (JB Weld? Fiberglass/resin? or replace the part?) Thanks
Old 04-28-2010, 12:10 AM
Monte's Avatar
Monte Monte is offline
Boat: 1986 Tristar 220 351 pcm
Is it leaking water or exhaust?
Old 04-28-2010, 08:50 AM
it's spiting water from the forward seam
Old 04-28-2010, 08:58 AM
Monte's Avatar
It looks like you can repair it.
http://www.wakeworld.com/forum/showthread.php?t=79636
Old 04-28-2010, 09:19 AM
slickwater1 slickwater1 is offline
just got done doing mine. I have a ps190 and all four of the exhaust ports on the muffler were leaking. took it off, sanded the areas applied resin and mat. looks like brand new.
Old 04-28-2010, 01:31 PM
sounds like good news, removal looks like it should be straight forward enough, are there any tricks I should be aware of? can you recommend any specific products? I'm all ears...
Old 04-28-2010, 01:57 PM
Craig's Avatar
Craig Craig is offline
Boat: Not a MC
I have patched a small leak where a bolt rubbed a pinhole in the exhaust with JB Weld, it has held up for over a year now. The hole was maybe 4-5mm in diameter.
A crack where the tube changes shape as it couples to either side of the exhaust hoses (as described in the Wake World post) will fail quickly with a JB weld fix. Patching with some fiberglass would be the best way to go in that situation.
94 Prostar 190, LT-1, Powerslot [SOLD]
Old 04-28-2010, 02:07 PM
Thanks, this leak on the bend from where the larger diameter cylinder bends down to the smaller diameter neck that is connected to the hose coming from the engine/manifold, sounds like I'm heading toward my first try at working with fiberglass, is all fiberglass created equal? or is there a particular type better suited for this application?
Old 04-28-2010, 02:27 PM
AUFan AUFan is offline
Boat: 1999 Maristar 210VRS
When I bought my 99 Maristar, the dealer had patched my exhaust with JB weld. Lasted only two seasons and was a PAIN to sand off. I put some fiberglass on it this past weekend. I went to Advance Auto and got the fiberglass mat and used Bondo resin/hardener.
One first timer to another, make sure anything you use that touches the resin/mat is disposable. Also, the fumes are terrible. I did it in my garage with the fans on and door open and still walked away with a rockin headache from the fumes.
Good luck! Should be a no brainer!
Old 04-28-2010, 02:37 PM
etduc's Avatar
etduc etduc is offline
Boat: Something else, DD 2004 red/white/black
Auto parts house, generally will have a fiberglass kit. It's pretty simple. If you just have pin holes, JBweld will work. Sand and clean the area, first, befor applying.
Don't over tighten exhaust hose clamps.
Ayyyy!
