Old 08-01-2013, 07:24 PM
ejkjell's Avatar
ejkjell ejkjell is offline
Boat: Prostar 197
Oil-bath wheel bearings
How often does the fluid in the oil-bath wheel bearing assembly need to be flushed or replaced?
I've moved my 2004 Prostar 197 boat and trailer cross country 4 times and I haven't had any issues and the fluid has remained at a constant level since I bought it. Love this trailer!
Old 08-01-2013, 08:30 PM
vogelm1's Avatar
vogelm1 vogelm1 is offline
Boat: 2005 MasterCraft ProStar 197, MCX
Annually would be a reasonable change interval, just in case the oil is contaminated with water. If there is a significant amount of water in the hub, the oil will become milky in color.
2005 ProStar 197 w/1:1 MCX; Acme #843; 2007 MC ZeroFlex Tower
Old 08-01-2013, 09:44 PM
93Prostar190's Avatar
Annually ?
Yikes got to go !
2008 Prostar 214 MCX
Old 08-01-2013, 10:36 PM
uplander uplander is offline
Boat: MC 2002 X30
pretty simple to drain, I have one giving me trouble so I actually drained and refilled minutes before leaving for vacation. make sure you find out the proper weight of oil to use for your hubs. mine takes straight 50W motor oil.
If using trailer considerable miles I would do annually
Old 08-02-2013, 10:23 AM
bturner2's Avatar
bturner2 bturner2 is offline
I didn't do mine for the first 5 years but I only trailer about 5 times a year. If the oil is clear (not milky) you're probably OK. Annually is probably MCOCD unless you're putting some serious miles on or you're getting water in the hubs in which case you have another problem that needs to be addressed. That being said changing it annually certainly isn't going to hurt anything either. Personally I've gone to flushing the brake fluid annually (which is probably MCOCD) and pulling apart the calipers and changing the hub oil every other season.
