Old 07-05-2012, 03:04 PM
Jerncalled Jerncalled is offline
Boat: 2010 197
Leaking bilge seal on 2010 MC197!
I recently had my 2010 197 put in the water and discovered I had water coming into the bilge.
I then had my dealer/local Mastercraft repair shop take the boat out of the water.
They say it was a leaking seal around the bilge plug. The plug was apparently sealed with silicone. "the repair tech said, "this happens all the time {to new boats}."
Really.
One buddy of mine said, " I wouldn't seal anything below the waterline with silicone.
Plus, you have a new 60k + boat' it shouldn't do that!"
This is my feeling. Brand new boat shouldn't be leaking. Plus the MC shop tells me this is not under warranty. So the repair guy sealed it with 5200 caulk. Tough stuff. But why is this not used in the manufacturing in the first place? Again, this is a 60k+ boat! Doesn't seem right that MC would use an inferior product when using a 5200 caulk wouldn't have cost them much more. Now I have to pay for my dealer to haul the boat out/in and do this work all due to a poor choice in caulk? If I had not noticed this in the very beginning my boat might have sank!
My question is:
Is this in fact standard manufacturing process for MC (or any other manufacturer) to seal with silicone at the under-the-waterline water points-of-entry (bilge plug, raw water intake, rudder post, stuffing box, bolts through the transom at the swim step)? IT seems to me that if this is a manufacturing choice that causes me to spend money on the boat in the first 3 years then I should not have to pay for the repair of an issue that could have/should have been done right in the first place. Car manufacturers have recalls for these issues, right?
Thank you for any insight you all may have!
Jerncalled
[/font][/font][/size][/size][/size][/size][/font]
Old 07-05-2012, 04:00 PM
Philscbx's Avatar
Philscbx Philscbx is offline
Boat: 78 S&S, 04 Pro 209
I would of lost it - I don't use that junk for a bathroom -
maybe time they spec whats used for submarines.
The 5200 sample tests I have cured on the bench are impressive.
Old 07-05-2012, 09:00 PM
OHpage21 OHpage21 is offline
Boat: MC, X9, 2006, RTP-1
I pulled my rudder box on my 06 x9 tonight. It was sealed with Silicone as well. I am actually very happy they didnt use 5200 on it as it makes it significantly harder to remove. I would suggest 4200 as it is removable on a part - such as a rudder box with could require removal for repair or rebuilding after time.
BUT - I agree with your point. A 2 year old boat shouldnt leak.
Old 07-06-2012, 07:50 AM
Boat: 2010 197
philscbx,
Thank you for your words of encouragement. Also duly noted regarding the
5200 product. and yes, perhaps I should be more outraged.
Mastercraft? what do you think?
Old 07-06-2012, 07:53 AM
Boat: 2010 197
Ohpage21
Thank you for the tip on the 4200. but should this not be on the
boat in the first place? jc
Old 07-06-2012, 08:06 AM
I was surprised it was silicone on mine as most threads i have read mentioned it being a difficult remove based on sealant. I would say out of the factory is should be a marine sealant, not a pliable silicone. 5200 and 4200 are both marine sealants from 3M, 4200 just doesnt require heat and debond solution to remove.
Old 07-08-2012, 10:08 PM
Boobaychap Boobaychap is offline
Boat: Maristar 215 SS, 2007, 5.7L
How can you test for this?
About two weeks ago, my 07 Maristar 215 SS starting taking on water in the fwd bilge. Takes on water both underweigh and at rest--no discernable difference.
Was thinking it might be the seal for the speedo or water temp sensor but after reading this thread, am thinkng it may be the drain plug.
How can I test to identify the source?
Also, what's the procedure to reseal the plug? Is this a task better left to pros?
Many thanks,
Boo Bay
Old 07-09-2012, 02:08 AM
Philscbx's Avatar
Originally Posted by Boobaychap View Post
thinking it may be the drain plug.
Hopefully it's out of the water -
any chance the threads are damaged / cross-threaded and not sealing?
Testing could be tricky - I would try - (dreaming this up as we go) - a plunger that fits in this zone.
A low profile test plug /teflon tape on threads/ so plunger can slid over it when bilge filled with water an inch or so.
Compress plunger & release a few times to fill plunger as much as possible with water - then apply constant pressure - filled plunger of water over plug.
By yourself - may have to set up video to see drain plug up close - review to see trace of leak.
If not leaking around flange of drain - thats a good sign threads are maybe the cause.
If plunger is a no go - may have to fill it more to create enough pressure to see leak.
Couple drops of dish soap makes water wetter testing.
Good luck - image would help.
Old 07-17-2012, 07:47 PM
More clues
Many thanks for the reply.
Not sure if its related but the widget in the photos below has detatched from the hull inside the fwd bilge.
Any idea what this is and how to reattach it?
Regards,
Boo Bay
Name:  Bilge photo 1.jpg
Name:  Bilge photo 2.JPG
Old 07-17-2012, 08:02 PM
vogelm1's Avatar
vogelm1 vogelm1 is offline
Boat: 2005 MasterCraft ProStar 197, MCX
That is the transducer for you depth gauge. It reads depth right through the hull. Typically mounted in a puddle of epoxy - it looks like it just popped off the smooth surface. I would take some course grit sand paper (80 grit or so) and rough up the area where it was mounted. Then clean that area really good with alcohol...mix up some two-part epoxy and re-attach. Done.
2005 ProStar 197 w/1:1 MCX; Acme #843; 2007 MC ZeroFlex Tower
bilge, leak, plug, rudder post, silicone
