Old 08-28-2012, 02:20 PM
Boobaychap Boobaychap is offline
Boat: Maristar 215 SS, 2007, 5.7L
Throttle Safety Collar is Stuck on my '07
The throttle safety collar on my '07 Maristar 215 SS is stuck in the up position--will not lock in neutral.
This is real safety issue because the boat can go into gear if you inadvertantly bump into the throttle while in neutral.
I believe this to be a corrosion problem and want to disassemble the throttle and inspect & lubricate it.
I'm looking for a manual with an exploded diagram. Picture of the throttle follows.
Can anyone identify the make and model or provide a link to the manual? All advice appreciated.
Thanks,
Boo Bay
Old 08-28-2012, 04:08 PM
milkmania's Avatar
milkmania milkmania is offline
MC Platinum
Boat: White/Red 91 PS 190
Thanks,
Boo Bay
only have knowledge of my 91
but, the ring had a connecting rod that went down the shaft to a pivot block... there was a spring around the shaft (can't remember whether spring was at top or bottom of rod)... the block pivoted in and out of a notch at the rotating part (forward and reverse)
disassembled, lubed it, added a stronger spring and reassembled
edit:
seems like the maker was Teleflex
look at page 10
http://www.teleflexmarine.com/wp-con...ion_manual.pdf
WE LIVE IN THE LAND OF THE FREE, BECAUSE OF THE BRAVE
Team MasterCraft Google Search Engine
