Old 01-15-2006, 12:35 AM
bucky's Avatar
bucky bucky is offline
Boat: '01 PS 190 EVO, 330 LTR, Powerslot, PP Dig Pro, ZeroFlex minitower
Dead Impeller
Probably the first post to cover this topic EVER! Changed this out late last year. The only sign of trouble was a rise in temp of about 2 degrees under hard use. Very hard to tell unless you're paranoid.
Old 01-15-2006, 12:36 AM
bucky's Avatar
And don't forget to clean your cooler.
Edit: ignore the date. I can't program my VCR either.
Old 01-15-2006, 12:41 AM
PendO's Avatar
PendO PendO is offline
Boat: 06 197 1.26:1 MCX (Gone but not forgotten)
Man, that is shredded ... I am thinking about replacing the ballast impellers with these Globe run dry impellers
THE ONLY IMPELLER IN THE WORLD THAT'S GUARANTEED TO RUN DRY FOR 15 MINUTES! ... I bet they also make one that would work in the water pump ... wonder if it would last longer?
Old 01-15-2006, 09:28 AM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
I believe that Indmar uses Johnson pumps. Which model is it, and which of these dry-run impellers is appropriate?
'04 MariStar 230VRS/MCX
Old 01-15-2006, 09:33 AM
Tom023 Tom023 is offline
Boat: 2001 X30 LTR
I have a globe impeller in mine right now, so far no problems, but as long as you change every year, I believe all that is necessary is a good quality one. Mine uses the #BRC-100V (Johnson #09-812B replacement), which cost $26 when I bought it, inflation I guess.
http://store.hamiltonmarine.com/sear...hterm=impeller
2001 X30 LTR
