Old 06-21-2005, 11:07 PM
bucky's Avatar
bucky bucky is offline
Boat: '01 PS 190 EVO, 330 LTR, Powerslot, PP Dig Pro, ZeroFlex minitower
Towing another boat
I was reading in the "problem child" thread about towing other boats, and wondered where you tied off to your boat. Is it safe to use the ski pylon to pull another boat? It looks solid but I'm afraid if I snapped it off it could get expensive. Would the eyes on the stern be better?
Old 06-21-2005, 11:43 PM
Mag_Red's Avatar
Mag_Red Mag_Red is offline
Boat: 2004 Prostar 209
I would definately use the rear tow eye. Lot of difference between a 200 lb skier and a 3000 lb boat.
Old 06-21-2005, 11:45 PM
Bongo Bongo is offline
Boat: 2004 MasterCraft 197 TT
I agree with Mag_Red. At that much weight, pull from as low as possible and lower the lever. I'd not think about towing another boat from the ski pylon unless it was a rubber raft with the Old Milwaukee Swedish Bikini Team.! (Dating myself, a bit.)
Bongo
SKI*MC's Avatar
SKI*MC SKI*MC is offline
Boat: MasterCraft, Stars and Stripes, 1983, 351 W.
Send a message via AIM to SKI*MC Send a message via MSN to SKI*MC
It depends if you are towing for long distances, or short, and the water conditions. We had to tow our boat the other week because of engine problems, we hooked it to eye underneith the bow. Since the boat is not running, the bow does not raise like it does when your are going. This can become a problem when towing at a speed more then 10 MPH on rough waters. You can tow, but keep it slower no matter what the water conditions!
You don't have to buy a lake to own it~MasterCraft
Old 06-22-2005, 07:21 AM
Boat: 95 PS 190 EFI
I tow my 9,000lb dock twice a year. At first I tried to use the rear "eye", but had a heck of a time steering (remember, our boats rear turns when we turn). Had to switch to the pilon. Granted, it's only 1/10 of a mile, but it is against the current 1/2 the time. No problems so far. My neighbor used to tow his similiar weighted dock approx 5 miles the same way for 15 years and no problems.
One thing I will tell you is to be sure you hang a couple towells/life jackets, etc over the towing rope just in case it breakes. They should keep the line from slingshotting back & peeling someone's head open.
I usually tow just on the other side of "in gear". Approx 1200 RPM's
If one day you're asked:
Will you say:
It's time to SKI.
Old 06-22-2005, 08:33 AM
BriEOD's Avatar
BriEOD BriEOD is offline
I've done the same as Jim. I use the pylon but go very slow.
Old 06-22-2005, 09:04 AM
T Scott T Scott is offline
Boat: It's always changing! Current Boat 2006 X-45
I also agree with Jim and Brian...I always tow from the pylon. I used to ski on a waterski show team and I figure if the boat can pull 10 skiers off of a dock for a pyramid from the pylon, then it should be able to tow another boat. Keep in mind, the eye in the back of the boat is simply drilled through the gel coat and secured with a backing plate. The pylon is supported by a beefy aluminum beam that is tied into the stringers and is also bolted to the floor of the boat. To me, the pylon is by far the strongest part of the boat.
Old 06-22-2005, 09:33 AM
jkski jkski is offline
Here is one for you.......... I watched a ski show one night where they were pulling a 4 tier pyramid off the dock using 2 boats hooked together, you guessed it, by the pylons. The front boat hooked a rope onto their pylon and it ran back to the back boat, through their open windshield and connected to their pylon, where the pyramid ropes were also connected. The lead boat was an MC naturally, and the second boat was a CC. In any case, it was a great stunt and the pylons held fine.
Old 06-22-2005, 11:20 AM
east tx skier's Avatar
Boat: 1998 Ski Nautique
I've used the rear lifting rings and never get out of idle towing another boat. I figure, if those rear lifting rings can be used to lift the boat temporarily, they should be beefy enough to pull a boat through the water at 5 mph.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 06-22-2005, 11:28 AM
milkmania's Avatar
Boat: White/Red 91 PS 190
depends what I'm pulling.....
the two that I have pulled, were a runabout and a pontoon
I tied off to the rear lifting eyes one my boat, the had one of the passengers on their boat HOLD the end of the rope....giving them firm warning to release if anything goes wrong. getting underway seems to be the most difficult time, once underway there's not a lot of drag.
