Old 09-04-2014, 08:30 PM
kecusc kecusc is offline
Boat: 2006 X45, 2004 X30
1100lb sacs in X30
Originally Posted by Bohmer410 View Post
This is with a rear locker, ski locker and bow full with only my wife in the boat.
Hi Bohmer410, I was wondering if you might be able to post some pics of your 1100lb fats acs filled in the rear lockers. I have a 2004 X30 and I'm getting ready to do an overhaul on the ballast system and bags. I've seen various posts about the 1100lb bags, some say they fit others say they don't, and even others say you can't fill them all the way. Just curious if yours fill completely and how the divider between the locker and engine is impacted.
Thanks for any help you can provide. I'm going to be adding the IBS bag as well and keeping the stock ski locker bag. I'd love to put the IBS on its own dedicated pump and switch, but not sure how difficult this would be with venting, etc.
Old 09-04-2014, 09:50 PM
uplander uplander is offline
Boat: MC 2002 X30
I have the same boat but went with the 900, I also fill the KGB locker.
Takes about 30 minutes to pull the stock tank and put bag in
Old 09-05-2014, 01:27 PM
What make of bags did you go with? I've seen a couple different brands (i.e. sumo, ronix, etc) but FlyHigh doesn't appear to sell them.
How's the surf wake with the 900's? Any pics you'd be willing to share of the bags and wake?
Thanks.
Old 09-08-2014, 05:04 PM
Bohmer410 Bohmer410 is offline
Boat: 2002 X30 3,000 Ballast
I don't have any pictures of them full. I'll take on the next time I'm out. Which might be two weeks away, I have a couple of wedding to go to.
They don't fill up completely, I would guess around 950 or so. I thought if I purchased the 750's I would eventually pull them out and put in the 1,100's later. Since there wasn't much of a price difference, I would just go with the 1,100's.
I have not reinforced the wall. It hasn't bowed or anything. At least yet, I've had 1,100's for one season. I've seen people reinforced them. It doesn't look hard to do. I'm going to hold out until it needs it.
For IBS, I would do a piggyback system off the ski locker.
I would highly recommend, adding two 1 inch thru hulls and removing the manifold. Then run 1 inch hose while your redoing it.
I like the 1 inch premium hose from wakemakers, but you'll need a lot of hose. I believe I used 60 feet. Also, I had better luck with lowe's check valves compared to wakemakers valves.
Old 09-11-2014, 04:46 PM
LCA1971 LCA1971 is offline
Boat: 03 X30 MCX
Bohmer410, What lake do you guys go to?
Old 09-11-2014, 04:59 PM
This year we have been to Cumberland, dale hollow, cave run, East fork, Norris and the river. We go to Cumberland most of the time. Then the river on the off weekends, since it's 15 mins away. How about you?
Old 04-18-2016, 01:34 PM
Mx-112 Mx-112 is offline
Boat: Mastercraft x10 2001 5.7 ltr vortec ltr
2001 X10 wakeboard & wake surf ballast set up
I have a 2001 x10 with stock
-250lb tanks in the rear lockers
-stock bag in the floor ski locker
I'm looking to add additional bags to make a much larger wake for wakeboarding.
I also wouldn't mind being able to switch the lay out around for wake surfing. Can some one give me some advice on what size bags to buy and where to locate them in my boat thanks.
Old 04-18-2016, 01:35 PM
X10 2001
Layout
Old 04-18-2016, 02:30 PM
jafo9's Avatar
jafo9 jafo9 is offline
Boat: 2002 X30 LTR
your best bet in the rear is to pull the hard tanks and replace them with a single bag. i haven't seen any posts from anyone who regretted pulling them. i'm not sure what you can fit in the x10. i'd guess at least a 750. you can replace the center bag and run an overflow to under the front seats. call wake makers.
