Old 06-20-2016, 12:39 PM
brucepalombo brucepalombo is offline
Boat: 2008 Mastercraft X-35
Gatorstep install
Getting ready to install the Gatorstep flooring...from swim to bow.
Bruce
Mastercraft X35
Old 06-20-2016, 12:40 PM
The swim platform prep and step was a PITA to get a good clean surface
Bruce
Mastercraft X35
Old 06-20-2016, 12:47 PM
Here's all the pieces I'll receive
Bruce
Mastercraft X35
Old 06-20-2016, 01:13 PM
cwarndahl's Avatar
cwarndahl cwarndahl is offline
Boat: X-45 finally better then x-10
That looks like it will be awesome. can't wait to see the completed project!
2012 MC X-25
Old 06-20-2016, 05:05 PM
cobalt650's Avatar
cobalt650 cobalt650 is offline
Boat: 2017 XT23, 5500
I just ordered Gatorstep-can't wait to see your pictures, and hear any advice or tips from the install!
Old 06-20-2016, 07:17 PM
TJ is fantastic...he only lives about 1.5 hours away and drop off all my templates at his house.
I'll be posting the pictures and tips as I go. One reason I went with Gatorstep, when installing it, you can lift up and re-stick if you make a mistake or need to move a little. The others...you stick...you're stuck
Bruce
Mastercraft X35
Old 06-21-2016, 09:22 PM
Just got done installing the gator stops. The process was fairly easy. It took me about two hours, but I'm also pretty neurotic. Here's a few suggestions
1. Clean the surface thoroughly with Windex not degreaser, but Windex. Let all the surfaces dry thoroughly. I spoke to the owner and they preferr to use Windex
2. Lay out all the pieces down and tentatively use masking tape to place them in your boat. This will get your alignment straight
3. Start with a small piece and get use to working with the materials. Slowly roll the material down and stick. If you try to lay flat, you'll get bubbles. The great part about Gatorstep, if you do get bubbles, you could peel reapply in you're good.
4. For larger pieces, just peel little of the backing back, stick and slowly peel away the backing and continuing to stick in place.
5. Once the piece is adhered to your boat, use a rolling pin to ensure that proper adhesion has taken place. Use a damp cloth (barely damp) and run your finger around the edge to ensure the edges adhere.
6. I also used a wet cloth and traced around the black inlays, this is a good way to identify if bubbles were there. You do hear a small cracking noise if bubbles are present. Just peel off and reapply. If you use your finger...it gets HOT fast...ouch...learned the hard way
7. Be cautious about stretching the material, as the edges might not come out a straight line. In some areas I've could've stretched it a little bit more, but I preferred it to be straight versus trusting my stretching skills.
8. When you're done, get your eye real close to the floor and look at it across on an angle. You'll see any minor bubbles that are bulging.
9. When I finish, I put on a pair of flat bottom flip-flops, and hopped on the gatorstep just to ensure it adhered to properly
10. Note to self, don't do it in the middle of a heat wave in California when it's 108 in your garage
Bruce
Mastercraft X35
Old 06-21-2016, 09:26 PM
Bruce
Mastercraft X35
Old 06-21-2016, 09:29 PM
Here's the interiorName:  image.jpg
Bruce
Mastercraft X35
Old 06-22-2016, 12:18 AM
kvw4x4 kvw4x4 is offline
Boat: 2007 black mastercraft x15 going on 1700 hrs sold! Upgraded to a 2013 mastercraft xstar 👍
Looks awesome, nice work!
2013 mastercraft xstar 7.4 522hp motor added gen 2
