Old 07-22-2013, 01:18 PM
AZDave's Avatar
AZDave AZDave is offline
Boat: 1993 Stars & Stripes Prostar 190 351 285 hp
Slight Vibration...still
I have a 93 ProStar that has always had some vibration. The coupler gap was checked a few years back, and I have added a 4 blade. It runs pretty smooth compared to other like Mastercrafts. The packing is origional, and the raw water pump new, and vibration free. No play in the strut. 700 hours. Any tips out there on fine-tuning this to a little less vibration.
Old 07-22-2013, 02:11 PM
Is shaft with .003 of being straight - has that been checkd?
Old 07-22-2013, 04:28 PM
AZDave's Avatar
No. Is there an easy method to check this? Do these things warp over time? I heard of a similar boat with a slot break off at the prop. I inspected the end for any cracks.
Old 07-22-2013, 05:11 PM
not hard - just need one of these.
here's the tool -- yes I know it's harbor freight -
http://www.harborfreight.com/1-inch-...cator-623.html
i know it's not a prop shaft but it works
here's a video http://www.youtube.com/watch?v=jtlPTJSNfwo
Old 07-22-2013, 05:16 PM
Good Answer!
Old 07-22-2013, 05:17 PM
Why.... thank you Peter... -- learned much of MC everything here on this fine forum from the great people here...
Old 07-22-2013, 05:28 PM
I have learned a lot here myself. Most people wouldn't realize checking your prop shaft is as simple and cheap as it is.
Old 07-22-2013, 05:30 PM
cruiser cruiser is offline
I did a lot of work on 30ft. plus chris crafts years ago with the same problems. If the shaft is straight, prop is straight and balanced and the key slot and key way are cut to proper depth. By this i mean put the prop on without the key in place and mark with a black marker, then remove the prop, install the key and replace the prop. It should go back on to the mark. If it does not you have to mark with hi-spot blue and scrape it in. If the prop does not go on to the same location, under load you can get a vibration from what we used to call Prop Wiggle.
Old 07-22-2013, 06:05 PM
AZDave's Avatar
I will try the dial indicator. I installed the prop using cruiser's procedure, Even did the whole prussian blue check. The dealer charged $100 to check the gap on the coupler. How hard is this?
Old 07-22-2013, 06:09 PM
John 14:6
