Old 06-05-2006, 12:23 PM
Tennessee J's Avatar
Tennessee J Tennessee J is offline
Boat: MasterCraft Prostar 205 1996, chevythang
Question Engine Overheating : Running HOT!
Engine is overheating. Yesterday I noticed the temp was up to 200 and trying to climb. I only noticed because the engine cut itself back as we were cruising. (I guess the it governs itself to cut off if getting too hot) I pulled back on the throttle, and the temp dropped to normal within about 3-4 minutes. We checked for any signs possible, but did not notice anything out of the ordinary. Besides this, the engine sounds fine. Any suggestions?
Old 06-05-2006, 12:31 PM
vogelm1's Avatar
vogelm1 vogelm1 is offline
Boat: 2005 MasterCraft ProStar 197, MCX
Assuming you checked the typical stuff (oil/transmission level, impeller, tranny oil cooler)? The tranny cooler is an easy one to forget...if you remove the lower hose, or one on right side of the cooler, there is a screen in there that gets plugged with weeds, debris, etc. If it's not that and your impeller is good, I would say you need to look at the thermostat next.
Old 06-05-2006, 12:33 PM
sanjuan23's Avatar
sanjuan23 sanjuan23 is offline
Boat: 1992 Prostar 205 w/351 H.O. 4 Blade CNC Acme
Check The Impeller And Water Intake For Grass Etc. Of Course If You Have A Closed Cooling System Whole Different Can Of Worms.
1992 ProStar 205 351 HO Acme 4 Blade
"The only reason people get lost in thought is because it is unfamiliar territory."
G-man's Avatar
G-man G-man is offline
My bet is on the impeller not getting changed in the spring
06 AWSA Approved Towboat
Old 06-05-2006, 12:55 PM
Thanks for the suggestions, I'll follow them up this week and hopefully be good to go by the weekend. - J
Old 06-06-2006, 09:37 PM
PerryBpilot's Avatar
PerryBpilot PerryBpilot is offline
Boat: 2000, Maristar 230VRS, 330HP LTR
Thumbs up overheat
Look at my thread cooling problems....overheating.
Several guys had great suggestions and helped me solve my problem!!!!
Check the transmission cooler the previous posts were not exaggerating at how easily it clogs and mine was actually pretty easy to get to.
GOOD LUCK!!!
