Old 05-03-2016, 11:33 PM
SpokaneSteve SpokaneSteve is offline
Boat: 2007 X1
Help with a new sub box please
Hello all:
I could use some advice on rebuilding a sub box:
Here is the old sub box:
Should I try to repair this and seal it with a marine epoxy?
Should I build a new one out of HDPE board? Something else?
All advice appreciated!
Thanks much, Steve.
Old 05-03-2016, 11:37 PM
bet_on_black's Avatar
bet_on_black bet_on_black is offline
Boat: 07 X-Star MCX
Start new, use birch plywood, coat with epoxy/bedliner, and add feet to lift it up and keep it dry.
Old 05-03-2016, 11:46 PM
Boat: 2007 X1
How thick of plywood? 1/2 inch or 3/4?
Thanks much. I want to get this done this weekend.
Steve.
Old 05-04-2016, 12:14 AM
dvsone79's Avatar
dvsone79 dvsone79 is offline
Boat: '99 205v
Steve.
3/4" MDF seems to work best for car stereo applications, so I would imagine the same thickness would be best if you're using plywood.
I used 3/4" MDF and sealed it inside and out with 3 coats of polyurethane, then carpeted it and used rubber feet to get it raised off the floor. Been going 3 years strong now.
Old 05-04-2016, 06:17 PM
Boat: 2007 X1
A couple final questions
OK - my local wood shop only has 3/4 inch marine fir plywood.
Is this acceptable? It's got to be better than MDF right?
Second, what type of sealing liquid should I use? West Systems epoxy, polyurethane, or something else?
Thanks very much for all the help!
Steve
Old 05-04-2016, 06:35 PM
Boat: 07 X-Star MCX
Steve
That plywood and epoxy will be awesome, and lightyears ahead of the MDF. Put some plastic feet on that bad boy and you'll be set.
Oh, and glue and screw everything together. Caulk the inside seams to keep it air tight.
Old 05-03-2016, 11:48 PM
MLA MLA is offline
Boat: pontoon
Nothing there to repair, sorry. Yes, start fresh, but HDPE is not needed. Construction methods will get you more likes than the material used. That enclosure looks 100% raw on the inside and may a poor coating of something on the outside.
Old 05-04-2016, 07:48 PM
lees23 lees23 is offline
Boat: 2017 22 VLX
What kind of sub was in there?
Old 05-05-2016, 03:15 AM
Boat: 2007 X1
JL 13W1v2-4
strangely it has a smaller amount of enclosed space than the old sub. Hopefully I can get close.
Steve.
Old 05-12-2016, 10:49 AM
Boat: 2007 X1
I'm no cabinet maker....
OK - here it is:
3/4 inch marine plywood - three coats of West systems epoxy in and out, starboard spacer to keep it off the carpet.
Wish me luck - it goes in tonight!
Cheers, Steve
