Old 08-02-2018, 05:19 PM
mastercraftka's Avatar
mastercraftka mastercraftka is offline
Boat: 2017 XT23 just traded the 2004 XSTAR, first was a prostar 190
ZFT4 Tower Speaker Locations
Ok, I would like to add another set of speakers but not real stoked on putting them right in the middle where I know I will hit them with my head.
Has anyone put them in a different spot? If so how did you do it?
2017 XT23
Old 08-02-2018, 05:23 PM
Bwag1961's Avatar
Bwag1961 Bwag1961 is offline
Boat: 2014 Mastercraft X25 w/Gen2 and Surf Pkg.
Mounted mine in the center but used the shorter mounts. Still have to remember they are there but looks good.
Sent from my SM-G950U using Tapatalk
A boat is a hole in the water into which you pour money......but it's a lot of fun!!
Old 08-02-2018, 06:17 PM
Do you happen to have a picture of your set up?
2017 XT23
Old 08-02-2018, 06:35 PM
Bwag1961's Avatar
Not the best angle from the mirror but you can see they are a little closer to the tower
Old 08-02-2018, 06:52 PM
cbreck0318's Avatar
cbreck0318 cbreck0318 is offline
Boat: 2017 XT23
I put my 7’s in the middle and mounted my 8’s on the outside. I haven’t had a problem with head room like I thought I would. Just use the low pro mounts. Saves an inch.
Old 08-02-2018, 06:55 PM
stuartjr stuartjr is offline
Boat: 2015 X10
You get used to them being there. I added two more to mine and hasn't really been an issue. As others have said use the low pro mounts.
Old 08-02-2018, 07:28 PM
mca1710 mca1710 is offline
Boat: 2015 X23
Here is a pic with the covers on. We have 4 8 inch. There is plenty of room to walk through the middle.
I still hit my head once a season
Sent from my iPhone using Tapatalk Pro
Old 08-02-2018, 09:37 PM
Morety's Avatar
Morety Morety is offline
Boat: 2016 X23; 2015 X20; 2014 X10; 2013 MB 21
Mount them where the mounts are. There will be plenty of headroom to walk through the middle along the SeaDek into the boat. Don't overthink it!
Old 08-03-2018, 09:45 AM
I guess I am overthinking it just seems like they would be in the way because we are constantly going back and forth through that back seat.
I can see from that one pic that the middle speakers are slightly higher than the others.
Did you guys that added them later get your speakers from Mastercraft or outside source and were they a matching set?
2017 XT23
Old 08-03-2018, 10:12 AM
Hunter Hunter is offline
Boat: 2014 X10
I got the white 880s from Earmark. But, I will only have two on the tower.
Does anyone know what size screw/bolt holds the speakers on the tower?
Never mind, as it appears it is 1/2 allen.
