Old 04-17-2013, 08:11 PM
f925's Avatar
f925 f925 is offline
Boat: 1990 Maristar 240 SC
Electrical diagram 90' maristar?
I am considering a complete overhaul of the electrical on my maristar. Is there a source for finding the schematics?
Old 04-17-2013, 08:14 PM
f925's Avatar
My main issues at the moment have to do with the electric choke (doesn't seem to work at all) and a loose purple wire coming out of the bundle with the orange Alt. wire that does not seem to have a home.
Old 04-17-2013, 08:17 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
That loose purple wire more than likely goes to the choke, it should have 12v purple to one terminal and the other terminal is ground.
/spôrk/
Old 04-17-2013, 08:25 PM
f925's Avatar
It is too short, and my choke is hooked up. One purple wire coming from the coil pack area, and the other terminal to the body of the carb (neutral). This wire is much lower and very short, or clipped. It can in its current state only reach the alternator body, but there seems to be no home for it.
Old 04-17-2013, 08:28 PM
Spork's Avatar
Boat: Sporkcraft
Could be the "exciter" wire for the alternator.
/spôrk/
Old 04-17-2013, 08:59 PM
I agree w/ J.mccreight regarding it being the exciter wire. On my '88, the purple exciter wire had a push on style terminal (not a ring) that just slipped onto a stud on the alternator. I inadvertently knocked it off once while doing something else on the motor, and didn't notice it. Couldn't figure out why the battery wasn't charging until I saw it dangling. I've since put a ring terminal on it and bolted it to the alt. for good. On mine, Both the orange and purple wires that go to the alternator are run together and exit the wire sheath at the same point Not sure why it came wired that way. Check the number of connections to the alt. It isn't a single wire type.
As for the choke, if you're getting 12v. with the keky on, I would guess that the bi-metallic coil inside the cover isn't engaged in its slot.
Old 04-17-2013, 08:30 PM
f925's Avatar
It is not either of these purple wires. But the upper of these 2 goes to the choke, and the lower to the breaker strip on the bell housing. Is there supposed to be a push to choke option on the ignition switch?
Old 04-17-2013, 08:32 PM
Spork's Avatar
Boat: Sporkcraft
No the choke is electric, when the key is on you should have 12v on the purple wire going to it.
/spôrk/
Old 04-17-2013, 08:43 PM
Spork's Avatar
Boat: Sporkcraft
If you have the 351w here is an old engine wiring diagram, it will be about impossible to get a wiring diagram for the rest of the boat maybe a Clymer manual will be helpful.Name:  351w diagram.jpg
/spôrk/
Old 04-17-2013, 08:51 PM
f925's Avatar
It is a 351w. Thanks so much, you have been a huge help tonight!
