Old 07-22-2012, 05:41 PM
OHpage21 OHpage21 is offline
Boat: MC, X9, 2006, RTP-1
Question for the mechanics
My wife has an 06 Malibu with 130K miles. She said it started to make a terrible clunking noise while turning the steering wheel left and sometimes right. I figured it was ball joints or tie rods gone bad.
I jacked it up this morning and checked it out. Ball joints are tight, tie rods are tight. No play in either.
Does anyone have suggestions? There was a recall on the steering column a few years back. Her car was in and it was replaced at the dealer.
Thoughts?
Old 07-22-2012, 05:48 PM
Footin's Avatar
Footin Footin is offline
Boat: 2007 Maristar 200VRS X2
CV joints?
OH-IO!
Old 07-22-2012, 05:53 PM
vogelm1's Avatar
vogelm1 vogelm1 is offline
Boat: 2005 MasterCraft ProStar 197, MCX
My first reaction is the CV joint. Sometimes the accordion boot on the front drive axle tears or gets brittle with age and dirt, grit, etc get in there and destroy the joint. And joints just wear out too. If you're handy with tools it is a DIY job. If it is indeed the CV joint, best just to get a rebuilt drive axle with new inner and outer CV joints; they are typically $125 - $250 depending on make/model. There's an axle shaft on each side, so you'll need to figure out which side is shot - roll down the windows and see if you can tell which side it's coming from. Hope this helps and good luck!
2005 ProStar 197 w/1:1 MCX; Acme #843; 2007 MC ZeroFlex Tower
Old 07-22-2012, 05:54 PM
Wouldnt CV joints create a constant thumping or whomping noise? It is a single clunk when turning the steering wheel.
Old 07-22-2012, 08:14 PM
vogelm1's Avatar
Yeah, it would be a thump, thump, thump, or click, click, click as it's spinning. By your description I wasn't sure if constant or just once during turning. In this case, I think Milk may be onto something with his links.
Old 07-22-2012, 08:00 PM
milkmania's Avatar
Boat: White/Red 91 PS 190
this might help
http://community.cartalk.com/discuss...unkknock-noise
http://www.justanswer.com/chevy/17z7...06-malibu.html
http://townhall-talk.edmunds.com/dir...ew/.f12e42c/52
Old 07-22-2012, 09:08 PM
That is everything i am experiencing with the steering system. You guys are excellent. Thank you for the help.
Old 07-22-2012, 10:05 PM
milkmania's Avatar
I'm not a real life mechanic, but I all my own stunts...... and google is my friend
just tell the wifey she needs to grease the shaft more often
good luck, I hope it's that easy of a fix for you.....
Old 07-22-2012, 10:31 PM
Thoughts?
Pittman arm, idler arm, center link, etc. Have someone turn the wheel with the engine off while you're underneath, looking for loose connections and listening for the clunk.
The steering column may be loose, too.
Old 07-23-2012, 02:26 AM
milkmania's Avatar
something that works very well for isolating noises is to use a 2 or 3 foot piece of rubber hose as a make-shift stethoscope....
