  #71
Old 02-16-2018, 11:43 AM
Double D's Avatar
Double D Double D is offline
Boat: 2008 X14, w/ LY6 400HP w/ 1.22 Ratio Tran
Originally Posted by scooter205 View Post
With it having new skins all around and as clean as it is, I still think I am going to go for it. I do wish it was EFI for simplicity, but we are fine with a carbed motor.
Sent from my SM-G935P using Tapatalk
Yes!!, good luck!
Check out the MasterCraft Buckeye Bash on Facebook!
"In my many years I have come to a conclusion that one useless man is a shame, two is a law firm and three or more is a congress." - John Adams
Old 02-16-2018, 12:07 PM
east tx skier's Avatar
MC Hero
Boat: 1998 Ski Nautique
11K is fine. 10K is better. At 10K, if it has the 4010 carb, you have some money to plop down on a 4160, and trust me, you'll want to do that (remove the cowl and see if it has two fuel feeds on the starboard side of the carb---that's the 4010). When it was a 94 at $11k, and now it's a 92, you don't have to worry about telling the seller why you want it for less.
That said, despite the wonderfulness of fuel injection, you can bolt on some mid range torque to that 351HO without much trouble or too much $$. They are all sorts of fun.
Be sure to hit up the FAQ section and print out the boat buyer's guide. It's helpful to have some ideas of what to look at so you don't just sit there and excitedly look at that pretty boat.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 02-16-2018, 07:33 PM
XC500mod XC500mod is offline
Boat: '18 x23, '15 x10
Originally Posted by waterlogged882 View Post
$10K would make me happy but as I said, $11K is OK because you have a nice low hour straight up engine. And a good find. I have observed folks search and search for boats that are in good shape and spend lot of time wishing and wanting.
Look at it this way: $9k - 11k is a decent range.... you're on the high side but the boat warrants it as well. If that were a 1200 hour boat (which is still low hours) that needed new skins and carpet, etc....I'd want to be on the low side (closer to $8.5K).
A 94 205 with EFI would be a deal for $11K but it's just not that year model.
If you get a junker somewhere else, you'll spend that delta and more on making it pURDy....Drop the cash and enjoy it and don't look back.
I paid $12k for a 93 190 with 421 hours in 2012. Worth it then and now. Yea, I'd like to have gotten it for 10 or 11 but it was there, in great shape so I jumped on it. I have put another $13k in upgrades. Still in my shop today.
I've been following this thread. I will likely never own a '92 205 but i like learning about this stuff.
Waterlogged, what have you all put into your '93 that totaled $13k?? can we get some pics?
To the OP here is my thought. If you have a boat that runs every time you go to use it and it's a mastercraft you're a lucky man. buy that thing!
Old 02-16-2018, 08:00 PM
Boat: 93 190
I have a few photos (actually a lot). Hopefully (S)cooter will not mind an innocent thread jack....thanks Cooter...
New after I got it:
  • 303 protectant gallon (Amazon)
  • 4 - Polk DB 651 cabin speakers (Sonic)
  • Blue Seas Isolator System with Perko switch
  • Boat Buckle tie downs for transom
  • new style pitot pickups (DIM)
  • Form fit water hose
  • Brass elbows for water hose to riser
  • Acme 541 prop
  • Impeller
  • Engine belts
  • Riser gaskets
  • Packing - dripless shaft packing
  • Registration numbers
  • battery box (2)
  • two Interstate batteries
  • battery cables_wiring (from genuinedealz.com)
  • Electrical Connectors_Sonic Electronx
  • Livewell plug (plug cooler compartment from outside of box; under floor)
  • Rockford amp
  • Pyle RCA Cables for Amp (2)
  • cable ties
  • Trailer Lights_eTrailer
  • Mirrors (DIM)
  • Shifter knob (DIM)
  • Fuel Sensor for tank (DIM)
  • Clean-check amplifier - Rockford Fosgate 400 watt (4x100)
  • Pebble texture Adhesive Black Vinyl Guard 9" wide Roll and 24"
  • 4 Flat Trailer Extension Male/Female Plug wire cord
  • Cable Ties and More_Shrink_Clamps_Wire Loom
  • Decals - Red Shadow set (BAWS)
  • fire extinguisher (2)
  • Teak Platform_First platform for 93 MC (Action Water Sports)
  • tires - Kuhmo (Tire Rack)
  • Head gasket set (DIM) - 175
  • GT40P heads (Tri-State Cylinder Head)
  • Head Install (Motor Head Kingston)
  • new hoses (water, exhaust) (DIM)
  • Impeller_Carb spacer plate_Spark plugs (DIM)
  • Clarion MC309 head unit (Sonic)
  • New upholstery (Viper)
  • New carpet (Viper)
  • wheels (from Team Talk - Morristown TN)
  • Perfect Pass Stargazer 3-event speed controller (Skier-to-Skier)
  • 105 amp upgraded alternator (DB Electrical)
  • Fuel line for PCM pump (DIM)
  • new raw water pump (Marine Parts Source)
  • Impeller/Seal/Gasket (DIM)
  • boat buddy, keel roller for trailer_etrailer
  • Boat buckle for bow eye (single)
  • stainless cupholders (2)
  • Epoxy 3M edge sealer for lettering
  • Teak wood for cupholders
  • Cell Phone-accessory holder
  • Bazooka RBCM-100 Bass remote controller (Sonic)
  • Bazooka MBTA8100_subwoofer (Sonic)
  • Aluminum Channel for seat riser (Grainger)
  • Polishing Cleaners/compound (Amazon / TCP)
  • Gas Lift Springs (3) engine cover/passenger back of seat
  • Polishing pads (Premium Boat Care)
  • Porter-Cable 7424XP Kit 6" Dual Action Polisher Kit
  • 3M Perfect II Extra Cut compound
  • 3M super duty compound (gallon)
  • Clarion MW1 Watertight Black Face with Stainless Steel Bezel Remote with LCD Display
  • Clarion MWRXCRET Marine Remote Extension Cable, 25 ft
  • PAC USBCBL 6-Feet USB Cable with Mounting Bracket
  • Heating pads for driver's seat
  • Grommets and Steering cable plate
  • Blower - Attwood - Baron USA
  • 12-Volt in-dash receptical
  • Kumho Tire - Tire Rack - Replacement $140_mount $10
  • Trailer Leaf Springs (2) - Northern Tool (installed Nov 2014)
  • Trailer Spring Parts - etrailer
  • Ignition switch (installed May 18, 2015)
  • Ladder for platform
  • Aluminum angle for cupholder - 4' stick - Grainger
  • Billet clamps for cupholders
  • Throttle cable brake
  • Steering wheel center piece - from TT memebr
  • Cover Sports boat Cover
  • XPC Dripless Shaft Seal Coupling (OJ Props)
  • Cutlass Bearing(OJ Props)
  • Audio Delay switch
  • Impeller
  • Exhaust Hose (Atlantic Boat Co. Amazon)
  • Grab Handle (6" - Iboat)
  • Third set of trailer wheels
  • Pertronix electronic ignition module
  • Flamethrower II coil
  • Carburetor refresh
  • Fuel filter canister kit (moved to rear where the battery was)
  • Engine cover sound deadener
I'm not much on posting "look at me" type stuff but since you ask...here are a few pictures. I took the entire boat apart and reassembled with the above...mostly all in one winter layup period. I have other costs not listed but this is the majority of the costs.
I was working away on this thing and finished it up for the coming season. One day I cleaned out my email and sorted mail that related to electronic transactions etc. So I decided to put the items in Excel (mistake for a hobby). It added up quickly. Never put your hobby in an Excel sheet.
Several large numbers from above: PerfectPass, skins, carpet, GT40P heads, two platforms, dual batteries......I also used (undocumented) a lot of stainless hardware from the local store and Graingers.
I moved the battery from the rear to the front (duals) so that required all new cable runs, etc.
I have recently rewired the boat with another $500 in material alone.
The engine is coming out this fall for a bottom up rebuild (upping the HP) that will run another estimated $5000 all-inclusive, and my labor for lifting, re-setting, and aligning is free to me...
John 14:6
Old 02-16-2018, 08:37 PM
waterlogged, that's incredible!
let me know when you want to sell.
Old 02-16-2018, 08:46 PM
Boat: 93 190
Thank you for the kind words.... It's a labor of love for me.
Things like this are what people do not realize that comes with the price of boats that have been restored. That is a perspective I consider when buying.....base price plus how much more will it cost me? I am usually upside down within one month of a purchase.
I did an 81 in 2017... Low base cost and put another $6,300 in it (stringers, etc).
John 14:6
Old 02-16-2018, 09:01 PM
2RLAKE's Avatar
2RLAKE 2RLAKE is offline
Boat: '13 x10 with 6.0 and '93 25th Anniversary Limited Edition
Looks absolutely incredible!
Old 02-16-2018, 10:06 PM
scooter205's Avatar
scooter205 scooter205 is offline
Boat: 1992 Prostar 205 351HO
New after I got it:
  • Acme 541 prop
  • Impeller
  • Engine belts
  • Riser gaskets
  • battery box (2)
  • Rockford amp
  • cable ties
  • Mirrors (DIM)
  • Impeller
Don't mind that hijack one bit. Beautiful boat.
Old 02-16-2018, 10:16 PM
MC25's Avatar
MC25 MC25 is offline
Boat: 2016 X30, 85 S&S
One of the best looking 190s I’ve seen.
-Aric
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
Old 02-17-2018, 11:14 AM
scooter205's Avatar
We got it. Well worth it in my opinion. Super clean and very well taken care of.
