Old 07-20-2018, 03:59 PM
pridnjoy pridnjoy is offline
Boat: 2013 X2 with Gen 2
Garage plans. Height of XT22 please
Working on designing a boat garage. What size door do I need for an XT22?
Old 07-20-2018, 04:32 PM
cbreck0318's Avatar
cbreck0318 cbreck0318 is offline
Boat: 2017 XT23
I can fit my xt23 in an 8’ door but it’s extremely tight and I believe the height of the 2 boats is very close. With that said I would recommend going bigger. If I had it to do again I would have 10’ doors.
Old 07-20-2018, 04:38 PM
tommydbouy's Avatar
tommydbouy tommydbouy is offline
Boat: 2009 X-15, MCX
Originally Posted by cbreck0318 View Post
I can fit my xt23 in an 8í door but itís extremely tight and I believe the height of the 2 boats is very close. With that said I would recommend going bigger. If I had it to do again I would have 10í doors.
How much clearance do you have? Is the opening on your door actually the full 8'? Mine is shy by a half inch.
Old 07-20-2018, 11:56 PM
cbreck0318's Avatar
Boat: 2017 XT23
Its about a 1/4 inch short of a full 8’.It’s super tight. I would say there is maybe a 1/2” of space if that. It’s really tight.
Old 07-21-2018, 12:04 AM
ProRMK ProRMK is offline
Boat: 2012 Mastercraft X2
they will go in an 8 foot door no problem... I have 94 inches of clearance and I make with an an inch plus to spare
Old 07-21-2018, 02:21 AM
Babyback's Avatar
Babyback Babyback is offline
Boat: 2017 XT23 6000 GDI
Call you local dealer and ask. I think the XT22 sits a bit higher on the trailer than the XT23. We have an 8FT garage and itís no problem.
Since you are building I would go 10FT and add some outlets to the ceiling above the boat and air conditioning to the garage. Weíll definitely the outlets...the air conditioning is an Arizona thing
2017 XT23 6000 GDI
Old 07-21-2018, 03:41 AM
campbellroofing campbellroofing is offline
2700mm high minimum 2850 mm wide absolute minimum leaves you about 40 mm spare each side of trailer guide poles thatís tower down on trailer for the door opening
Old 07-21-2018, 07:26 AM
JohnE's Avatar
JohnE JohnE is offline
Boat: XT22
If you're building it, go 10'. That's what I have and it's great for the XT22. I went 10' because the X14 with tower up cleared by an inch or 2.
Old 07-21-2018, 07:37 AM
FoggyNogginz's Avatar
FoggyNogginz FoggyNogginz is offline
Boat: 2017 X10
Location: Center Hill Lake, Old Hickory, and Norris Lakes in TN
Get a 10ft door. I just did this last year and it's perfect. No need to worry about it being so tight or close with an 8ft, and eventually you will buy different wheels, springs, tires, or a new boat and perhaps require the additional wiggle room.
Old 07-21-2018, 07:40 AM
JohnE's Avatar
Boat: XT22
That's what I meant, Kent.
