  #171
Old 01-13-2015, 01:19 PM
willg willg is offline
Boat: 02 X-Star
awesome... I really hope they work.. they look identical to the originals - since GM made motors for the russian LADA car which these came from - there's a good probability of them working... can't wait...
I sent the link to Indmar-enginenut so hopefully they well check them out as well.
mike
I tried to figure out what Lada they came from, but had no luck. Do you have any idea? Maybe that would make it easier to find a cross-reference that doesn't need to ship from china.
Old 01-13-2015, 01:21 PM
SikeCo is the company that makes it - the LADA was the only application - the I could find.
search LADA under Crank sensors.. http://www.sikeco.com/search.asp
Old 01-20-2015, 08:26 AM
Wakerider16 Wakerider16 is offline
Boat: 2001 Prostar 205V
Has anyone just tried straight up automotive sensors?
Old 01-20-2015, 08:56 AM
automotive sensors would work (I believe) if you got the right ones and had an oscilloscope.
I read that you received an additional set of sensors from Bruce. What are Bruce's thoughts on the change in resistance?
Old 01-20-2015, 11:46 AM
Bruce just said that all the sensors he gets are around the ~650 area. Per the Indmar troubleshooting guide they should all be around the 800 Ohm mark. Indmar has said though that you can use sensors that are low in resistance as long as you get the proper voltage from them.
Old 01-20-2015, 02:07 PM
if the crank sensors are in the 650 area a 150ohm resistor will bring it up to 800 - just a mod to the harness would be needed - no?
Old 01-20-2015, 03:29 PM
the bigger problem is the 0 pulse voltage the sensors are giving off
Old 01-20-2015, 03:39 PM
That is a problem - are they the exact same length as the originals?
Old 01-20-2015, 03:41 PM
I hope Bruce does not have a batch of bad ones.
Old 01-20-2015, 03:52 PM
He said he plugged the second set into his engine before sending to me and everything worked so I am not sure what is going on...
