  #91
Old 02-07-2014, 12:03 PM
Here's another to try. SMP - PC-134 - 2 pole a little shorter - all these parts listed by application - not dimension or type - but most GM application are variable reluctor type.
Old 02-07-2014, 12:05 PM
Not sure if the attached picture will help. But I snapped this last year when I replaced water pump. No comments on MCOCD...I have since cleaned thing up. Part number on plate is there.
96 LT1
I bet we find one and have to him it. the one I did find appears too long - but a shim would work - saw that solution on youtube to solve a problem on a car - was actually a service bulletin cuz reluctor wheel was scraping sensor.
Old 02-07-2014, 12:13 PM
Waterskibum Waterskibum is offline
Boat: 93 S&S 190
Yep thanks for everybody's postings, and for Mike not giving up yet! I'll pull a sensor and head to auto zone tomorrow and dig through sensors.
96 LT1
Could swear my sensors are on the other side. I'll verify tonight.
Old 02-07-2014, 12:21 PM
Okay - Here are some more to look at I am starting to build a list. Changed the thought process a bit.. the LT1 Indmar development and testing took place a couple years before release so I found the Cadillac Cimmaron - similar ignition control module - similar Crank position sensors
The mount may be a bit different - looks like one Jessie tried - but these are different part numbers and they match the ignition module - visually.
SMP PC7 - ACDelco 213-336
********update******** Jessie tried the PC7 type --- I should crossed checked his GM part number. poop!
I wonder why it did not work - its a VR style - Jessie what happened when you tried the other one you bought? No Start?
Old 02-07-2014, 02:16 PM
gsxrjtt's Avatar
gsxrjtt gsxrjtt is offline
Boat: changes every month
JUST AN FYI ..... MY 1993 LIMITED is running like a CHAMP... HUGE THANKS to CHUCK the LT1 Genius and old owner of BAY AREA WATERSPORTS.. Helped me fix a starting issue with my boat now it starts every time..
Old 02-07-2014, 02:21 PM
mgs96ps mgs96ps is offline
Boat: A
Originally Posted by gsxrjtt View Post
JUST AN FYI ..... MY 1993 LIMITED is running like a CHAMP... HUGE THANKS to DAVE the owner of BAY AREA WATERSPORTS.. Helped me fix a starting issue with my boat now it starts every time..
Good to hear...are you still going to sell? Also, would you care to share what needed tweaked. As an LT1 owner it is always good to stock pile knowledge.
Old 02-07-2014, 02:24 PM
Boat: A
Just found out on another thread.
Old 02-07-2014, 02:31 PM
gsxrjtt's Avatar
Yes still for sale.. I just didnt feel right letting it go with out firing right.
So After about 6 hours of checking, rechecking, hooking up the computer and diag. Everything was checking out ok with no codes. Finally traced with proab to ignition, From there we checked grounds and voltages, Then chuck Finally looked at the connector that goes to the ign module. found if we wiggled or held it we would get some fire and coughing from the motor. so we took of the connector and found some of the pins were off so tried as much as he could to realign them. Put the connector back on and used a pin through the back of the connector to apply ample pressure to the connections and BAM about two turn overs and it fired right up. Turned if off then on fired up. Let it run for 5-10 sec and throttled it up to blow out any build up in the engine. turned it off then back on again.
Old 02-07-2014, 02:38 PM
Boat: A
So the real question here is.....how many good crank position senors do you have now- 4 or 6?
Want to send (2) my way? Send PM if you will sell.
Old 02-07-2014, 02:47 PM
gsxrjtt's Avatar
2 new went into boat I only have 2 new left.. Keeping those for future LT1 if I purchase one.
