Go Back   TeamTalk > Classifieds Buy/Sell > For Sale: Watersports Equipment
Old 06-22-2018, 12:14 PM
Zrlee's Avatar
Zrlee Zrlee is offline
Boat: Mastercraft XT22 2018 5500GDI
Over tower cover pooling 2018 XT22
Anyone else with the over tower cover having an issue with water pooling. I had the same issue in my previous NXT and was able to rework the straps to solve the problem. Hereís a pic from a quick shower last night. The cover is installed correctly and all straps and ratchets are tight. I was afraid of the over tower cover for this reason so I even put a 2Ē wood block under the support poles to add height and hopefully prevent pooling but that didnít work. Surely mastercraft can design a cover that doesnít retain water pools, right?!?
Old 06-22-2018, 01:12 PM
ap77's Avatar
ap77 ap77 is offline
Boat: 2015 MasterCraft X-20
Does the over the tower cover still require the poles to be put in place?
Edit: I just noticed you added height to the support poles...can you route the straps from the support poles over the tower to keep the cover higher up?
- Andrew
2015 MasterCraft X-20 (current)
2009 MasterCraft X-2 (sold)
Old 06-22-2018, 01:18 PM
Zrlee's Avatar
There are no straps to the poles anymore. With my NXT the poles w/ straps were separate from the cover and i was able to reroute the straps. But, now the caps for the poles are sewn into the cover so there are no straps to reroute.
Old 06-22-2018, 01:42 PM
CrashCourse316 CrashCourse316 is offline
Boat: MasterCraft, 280 SST, 2005, Twin 375 Crusader
Cut a 2x4 to length and put it in there. if you are worried about the 2x4 rubbing and wearing the cover in that spot. sand the end of the 2x4 and or put that 3m rubber tape or something on it. I have a 2x4 bow post. works great. didn't even cut it. It fit perfectly and it grips on the carpet/deck decent enough so it doesn't fall ever.
Sam
Website: www.SteadyPass.com
Email: [email protected]
Boat: 2005 Maristar 280 SST Twin Crusader 375
Old 06-22-2018, 02:10 PM
ap77's Avatar
Here are a couple of thoughts:
1) Can you extend the pole higher?
2) Can you put a rope or strap through the tower handles...maybe extend it to the windshield to keep the tarp higher up? Like below...
- Andrew
Old 06-22-2018, 02:14 PM
Maristar210's Avatar
Maristar210 Maristar210 is offline
Boat: paddle
No, no they can't
Old 06-22-2018, 02:22 PM
Zrlee's Avatar
Attachment 177331
Thatís an option! Iíll look into that.
Old 06-22-2018, 05:35 PM
REDX2's Avatar
REDX2 REDX2 is offline
Boat: Mastercraft, X23 2016
Straps hook to the tower
Old 08-24-2018, 05:27 PM
Zrlee's Avatar
Finally got around to coming up with a solution for pooling. Thought Iíd share for anyone else having the same issue.
Old 08-25-2018, 09:09 AM
JohnE's Avatar
JohnE JohnE is offline
Boat: XT22
I have had that problem only once with my XT22 - and it was because I didn't ratchet the straps tight enough and didn't use the trailer straps. Since then, I've had zero problems, and it has seen some torrential storms. Not a drop pooling. It's been so good that I have been thinking about starting a thread about how great the over the tower cover is. Seriously.
