Old 09-02-2013, 02:36 PM
Basketballtitan Basketballtitan is offline
Boat: 2013 Mastercraft X25
x25 Wake Problem
I just bought a new x25 a couple of weeks ago and am having a problem with the wake. The boat has the factory ballast as well as I had installed 450 lbs bag in each of the two back lockers. When I fill all up to 100% including the center tank, the wake is not clean at all when wakeboarding pulling me at 19 mph. I have the middle plate and surf tabs a -0-. Any tips on how to make the wake a little cleaner when wakeboarding?Thanks
Old 09-02-2013, 02:45 PM
Mastercraft13's Avatar
Mastercraft13 Mastercraft13 is offline
Boat: 2013 X-10 6.0
I would suggest some extra weight up front.
Old 09-02-2013, 02:52 PM
Nick911's Avatar
Nick911 Nick911 is offline
Boat: 2013 Mastercraft X25, 6.0 Ilmor, Pro Package, slammed and flaked!
You are way to rear-end heavy. Don't use those extra tanks in the rear for anything but surfing. Just fill stock you'll be fine. Otherwise throw a 750 in the bow walkway.
Old 09-02-2013, 03:05 PM
FourFourty's Avatar
Boat: 2018 XStar that's trying to be a 40th.
X3
Too much rear weight. And considering the wake that a 25 puts out on stock ballast, I would suggest simply emptying the rear sacks.
Old 09-02-2013, 03:46 PM
MC25's Avatar
MC25 MC25 is online now
Boat: 2016 X30, 85 S&S
I would suggest going faster. 19 is way slow
-Aric
LONE STAR MASTERBASH 2018
Details released eventually
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
1985 S&S- For Sale
Old 09-02-2013, 03:48 PM
Jonb1822 Jonb1822 is offline
Boat: 2017 X23 6.2L
Same as everyone has said plus remember that most times you add more weight you need to increase you speed. I have found 19mph to be a little flow when adding additional weight past stock ballast. Just another thing to check.
Old 09-02-2013, 04:31 PM
So would you say fill the side tanks at 50% and the middle tank at 100% as the side tanks are plumbed to the extra bags. Also what speed would you suggest? I am 6'5 195.
Old 09-02-2013, 05:31 PM
scott023's Avatar
scott023 scott023 is offline
Boat: 2008 X45 Switch L18
Have you ridden in without any ballast yet? That would be a good starting point, to determine where you need to go. The 25 had an awesome wake at 2122 mph with no ballast, even better with just kgb ballast filled.
Old 09-02-2013, 04:39 PM
GoinBoatin's Avatar
GoinBoatin GoinBoatin is offline
Boat: 2006 x-45 8.1L
Fill stock tanks and ride at 22mph
Old 09-02-2013, 05:49 PM
I did, however I was looking for a bigger wake. However, I did not just fill the kgb yet, I will try that next weekend as well to see how that works. As for the middle tab would you just leave that up or would you mess with that as well. Granted the extra 900lbs helped with surfing but for wakeboarding or kneeboarding was not crisp at all and I really did not like it at all.
