Old 08-19-2016, 03:08 AM
willg willg is offline
Boat: 02 X-Star
The problem has to be in the wiring behind the switch if the pump runs in one direction. Reach back behind the armrest with the switch emptying (the direction that won't work) and jiggle the wires for the switch and see if it comes on. I had this happen a few times on my boat.
Old 08-19-2016, 03:13 AM
Boat: 02 X-Star
This is how the pump/switch is wired.
https://www.wakemakers.com/resources...pump-switches/
If the wiring isn't the problem, it's the switch. Very standard DPDT rocker switch. Used on almost all boats. The cover that says "ballast" pops off and you can swap it over to the new switch
http://www.mouser.com/ProductDetail/...FhI0eXBA%3d%3d
Old 08-19-2016, 02:49 PM
Canadianwake Canadianwake is offline
Boat: 04 x2
Thanks for all your help guys, I am back at my boat next week so I will try checking voltage with a multimeter, then I will try checking out the wires and popping the switch cap off. is there enough room to see the wires behind the arm rest? or is it just a do by feel thing?
Old 08-20-2016, 08:58 AM
wheelerd's Avatar
wheelerd wheelerd is offline
Boat: 2005 X2
Once the switch cover is off -- do this gently to avoid breaking it -- you should be able to pop the switch out of the panel. There are two small friction tabs that secure it. Squeeze these and the switch will pop out. Then you will have access to the connections on the back of the switch.
205v, ballast pumps, x star
