  #21
Old 07-01-2017, 03:27 PM
Table Rocker's Avatar
Originally Posted by itsmetibbs View Post
Mine is the single terminal variety.
You might have three, one for the ECM, one for the gauge, and one that is a switch.
'96 ProStar 205 SD LT-1
Old 07-01-2017, 08:47 PM
itsmetibbs itsmetibbs is offline
Boat: 1995 Mastercraft Prostar
I found the sensor, and the sender. Those are near the Thermostat. Where is the switch at?
Old 07-01-2017, 10:29 PM
On my engine (as I recall) it is on the starboard side in the head.
Old 07-03-2017, 10:10 PM
my local marine shop had the ECT Sender Unit, and I replaced it. Like I mentioned before, it's the single terminal variety located on the starboard side of the engine. It looks like this: https://mcpartsdepot.com/products/se...1-2-npt-thread
It doesn't appear to have made any difference in how the engine runs. How do I put the engine in service mode to make sure the ECM recognizes the new part. Do I even need to do this?
Any additional thoughts would be helpful.
Old 07-03-2017, 10:38 PM
bret's Avatar
bret bret is offline
Boat: Prostar 190, 1993, Anniversary Limited.
http://www.rinda.com/marine/marine.htm
Code Mate is like $69 and up to MEFI 4, great tool. I have had mine so long I don't remember when I even got it
Old 07-04-2017, 08:47 AM
that's not it... 2 wire near rear of engine starboard side...
if it was the exhaust leak the spray from injectors would be the same -
have a video of it not starting with injectors?
get those exhaust gaskets replaced -
Old 07-06-2017, 12:00 PM
bochnak bochnak is offline
The ECT sensor is located under the #8 spark plug.
Here is the one I replaced last year:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
-Matt
Old 07-06-2017, 12:01 PM
MAP testing:
http://troubleshootmyvehicle.com/gm/...e-map-sensor-1
-Matt
Old 07-06-2017, 12:04 PM
Here is a link to MEFI 2 service manual:
https://drive.google.com/open?id=0B9...G1tb19vRU1IRVU
Not sure if you have MEFI 1 or 2, there are wiring differences.
-Matt
Old 07-22-2017, 11:12 AM
Quick update:
As I previously mentioned, the previous owner replaced the block. It appears that as he was doing so, he rerouted the wiring incorrectly. He routed the knock sensor wire and the ECT Sensor wire to the wrong side of the engine. My block did not have the ECT on the starboard side, but it has a plug in a place where I can install an ECT. I'm going to remove the plug and install an ECT. and I'm routing the wires into the correct position.
I was also getting a MAP code. I located a leak in the vacuum line leading to the MAP. Replacing the line should clear that up.
