Old 05-19-2015, 06:40 PM
972todd 972todd is offline
Boat: 2003 x-2. Indmar 5.7
Speaker wire suggestions
Changing out audio components in my x2. Wet Sounds in cockpit (sw-65). Will have 4 tower speakers (6 1/2") that I have not purchased yet. What gauge speaker wire would you suggest to each. Running just 2 amps.
Old 05-19-2015, 06:53 PM
ccelia's Avatar
ccelia ccelia is offline
Boat: 2009 Mastercraft X-45
If you are going to take the time to run new speaker wire, I would redo everything with 12 gauge. You never know when you will change out the speakers and want to run bigger power to them, although 14 would be sufficient.
I just installed this wire in my boat and I am very pleased with the outcome:
http://www.knukonceptz.com/mobile-au...-speaker-wire/
Old 05-19-2015, 07:34 PM
Boat: 93 190
+1
http://genuinedealz.com/ as an alternate place to consider. Tinned wire all the way.
John 14:6
Old 05-19-2015, 07:59 PM
MLA MLA is online now
Boat: pontoon
Cant imagine you will be pushing them wit more then 200W each, so 14ga would be fine all the way around. Now, with 4 pods on the tower, I would try to avoid running 4 sets of 2-con. I would run a 2-con for each side, and parallel a pair. Your amp choice here, will have some influence.
Old 05-19-2015, 10:29 PM
Thanks for the info. I'm assuming when running parallel to simply "jump" off to splice in another correct.?
