Old 05-17-2015, 11:16 PM
Cc4me's Avatar
Cc4me Cc4me is offline
Boat: 2014 Mastercraft X10
Wetsound Rev 8's vs JL audio tower speakers
Hey guys, I bought a 2014 MC X10 with 2 Wetsounds Rev 8's installed on the tower. They sound very "High". I also have the factory JL audio cans. The JL's are smaller and not as highly regarded but sound more "full". Is it normal for the Rev 8's to sound "high"? I know I can adjust, but was looking for input since the difference between the two sets of speakers at the same current setting is so obvious. Any feedback would be greatly appreciated.
Old 05-18-2015, 01:27 AM
Cain0725 Cain0725 is offline
Boat: 2006. Mastercraft maristar
make sure your amp is not in high pass mode… but generally Jl audio is great stuff for near listening. Wetsounds will work along ways away! I had JL and switched to REV 8 and i love them.
Old 05-18-2015, 02:38 AM
MC25's Avatar
MC25 MC25 is offline
Boat: 2016 X30, 85 S&S
the amp needs to be in high pass. otherwise youll blow the woofer. the horn is what makes the rev 8s seem high, just the general nature of the HLCD. the Rev 10s are much more of a full sounding speaker, at short and long throws due to the added size of the woofer.
the JLs are great for surfing. not so much at 75 ft
-Aric
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
Old 05-18-2015, 12:13 PM
MLA MLA is online now
Boat: pontoon
Absolutely run the amp on hi-pass. Being an HLCD, the Rev-8 is going to sound "bright" when next to a traditional coaxial like the JL 7.7. Its got a huge, powerful compression driver, so its going to dominate. Are these 4 pods all driven off the same amp? Are the wired in parallel on the right and left? I would consider selling the 7.7's and Rev-8 and get a single pair of Rev-10. Best of both worlds.
Old 05-18-2015, 01:46 PM
MrDearybury MrDearybury is offline
Boat: 2014 XStar
I think I know who this is!!!!
Old 05-18-2015, 03:51 PM
David Analog's Avatar
Boat: N/A
The JL Audio 770s are an excellent sound quality speaker at surf range or in close proximity at rest. They are exceptionally linear, meaning smooth over a broad range, good midbass extension, and 'flat' (treats all frequencies with equal amplitude).
However, if you want more authority at wake range you have to give up a portion of those attributes in exchange for greater output, even if the response has some peaks. There are no exceptions to this trade-off. Of all the HLCDs, the Wetsounds REVs will give you the best SQ.
I would recommend setting a priority and making a decision.
For example, If you need the extra output and projection then convert all tower speakers to the REVs. Then power them correctly. If you want to tame the treble for near field listening then a very modest adjustment on an EQ will moderate the treble. For articulate projection at wake range you'll need the treble back, hence the reverse EQ adjustment.
Old 05-18-2015, 11:09 PM
Cc4me's Avatar
I only have one set installed. I noticed the "high" or "bright" sound immediately from the Rev 8's. I adjusted the treble using the HU, but that didn't create the sound stage I was looking for. I then tried the JL 7.7's. I was surprised by the difference. I was only testing at a short distance not at the end of a line, but much more balanced sound. The high pass filter is already turned on the amp. You guys are right, I'll have to decide on my priority (short or long range) and make the decision from there.
The Rev 10's are huge! I can't lower the tower with the Rev 8's installed without scuffing my seats. I can't imagine how much damage the Rev 10's would do. I also can not swivel the board racks in with a board in the top rack with the Rev8's installed.
Thank you for the input.
Old 05-18-2015, 11:39 PM
Cc4me's Avatar
Garfield?
Old 05-19-2015, 09:02 AM
Boat: N/A
The treble tone control on the HU is very broad and very gradual. It might be hinged at 1 kHz and turnover (more or less flatten out) at 4 kHz with a range extending to the top of the audible limits. It's not the frequency-band-specific control that you may need. This is where a 4-band Wetsounds EQ comes in. Btw, the EQ has completely discrete EQs for the tower and in-boat zones so a tower adjustment won't influence the in-boat speakers.
jl audio, tower speakers, wetsound rev 8's
