Go Back   TeamTalk > Classifieds Buy/Sell > For Sale: Parts & Accessories
Old 01-31-2015, 03:46 PM
Dalilamba Dalilamba is offline
Boat: 2012 X25
JL Audio HD 750/1 amp for sale
JL Audio HD 750/1 Mono Block 750W amp
$400.00 OBO.
General Features:
•JL Audio HD750/1 750W Monoblock Class D HD Series Car Audio Amplifier
•RMS Power Rating (11V-14.5V): ◦4 ohms - 750 watts x 1 chan.
◦3 ohms - 750 watts x 1 chan.
◦2 ohms - 750 watts x 1 chan.
◦1.5 ohms - 750 watts x 1 chan.
•Max power output - 750 watts x 1 chan.
•LED power (green) and protect (red) indicators
•Mono/Single channel operation
•R.I.P.S. - Regulated, Intelligent Power Supply
•"Regulated" means that the power supply adjusts its operation so as to maintain the amplifier's rated power output and low distortion operation over a wide range of vehicle voltages (11V - 14.5V)
•This contrasts with conventional, "unregulated" power supplies, which allow rail voltages to sag in direct proportion to drops in the supply voltage
•The "Intelligent" portion of the R.I.P.S. System is a circuit that actually monitors output current to optimize the amplifier's output power over a wide range of load impedances (1.5 ohm to 4 ohm per channel)
•Bottom Line - Optimum power, at any impedance between 1.5 ohm and 4 ohm per channel, at any vehicle voltage between 11V and 14.5V
•Single Cycle Control - high-fidelity, full-range class D is a reality
•Tracking the audio signal, comparing it to the real PWM waveform and then correcting it in each and every cycle (over 400,000 times per second)
•Heavy duty aluminum alloy heatsink for heat dissipation
•In addition to the sonic benefits of Single Cycle Control Class D, the technology also results in outstanding efficiency
•Input sensitivity: ◦Low level: 200mV-2V
◦High level: 800mV-8V
•1 Pair of Buffered preamp RCA outputs for daisy chaining the audio signal
•Variable high-pass filter (50-500 Hz, 12 or 24 dB/octave)
•Variable low-pass filter (50-500 Hz, 12 or 24 dB/octave)
•Infrasonic filter (30 Hz, defeatable)
•Output polarity switch - Yes
•Frequency response: 6-8,000 Hz
•Dimensions: 10-13/16"L x 8-1/4"W x 1-15/16"H
•4-gauge power and ground wiring is required for installation
•Weight: 10 LBS
Amp is in great condition and was only used for a couple months im my X25 until I sold it. I paid over $700.00 for this amp. Sound is incredible. Here is a link to what it costs new http://www.crutchfield.ca/ProductDet...1&Show=ExtInfo $400.00 OBO Call or text 250 862 1797
Old 01-31-2015, 03:51 PM
MC25's Avatar
MC25 MC25 is online now
Boat: 2016 X30, 85 S&S
If only it was mhd....
-Aric
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
Old 02-05-2015, 08:29 PM
Boat: 2012 X25
bump.
Old 02-05-2015, 09:28 PM
MC25's Avatar
If you'll move on price and ship to tx I may be interested
-Aric
Old 02-05-2015, 11:06 PM
Boat: 2012 X25
What were you thinking?
Old 02-06-2015, 12:44 AM
Boat: 2012 X25
How does $375.00 shipped to you sound?
Old 02-06-2015, 10:00 AM
Boat: 2012 X25
Sold. Thanks Corbin and Teamtalk.
