Old 09-06-2017, 12:17 PM
Gvwolfe Gvwolfe is offline
Boat: 2006 Mastercraft X30
06 X30 Ballast Issue
Ok, looking for guidance on where to start looking. All 3 ballast pumps (stbd, kgb, port) stopped working this weekend. The toggle switches for fill and empty still light up but no water in either direction. Any ideas?
Old 09-06-2017, 12:50 PM
gt23's Avatar
gt23 gt23 is offline
Boat: 2015 X30, 2008 X15 (sold)
when you turn them on do you hear them working, or nothing?
have you checked the fuses/circuit breakers?
odd that all three went at once. not sure on your circuit board but look there first
Old 09-06-2017, 12:54 PM
gt23's Avatar
is it possible the inlet is blocked, if the motors are running it could be a blockage - unlikely I would think, but possible?
Old 09-06-2017, 01:10 PM
Nothing running at all. I'll check breakers to start. I found it strange that all 3 would stop at once
Old 09-06-2017, 01:40 PM
gt23's Avatar
that is very strange. first guess would be electrical
Old 09-06-2017, 02:38 PM
rgardjr1's Avatar
rgardjr1 rgardjr1 is offline
I would get your multi-meter out and check for power at the plug where it connects to the pump. I had a problem with one of my relays going bad so the pump would empty but not fill. I could tap on the outside of the plastic box with the relays and get it to come on. Weird that all three pumps are dead.
2006 Maristar 200 SS
Old 09-07-2017, 04:05 AM
tr6coug's Avatar
tr6coug tr6coug is offline
Boat: Mastercraft 2007 X2 MCX
Check the relay box and make sure the box is getting battery power. The power terminals inside the box might be loose.
'07 Navy Blue X2 MCX
http://www.wakeblaster.com/
Ballast Timer Reprogramming Info
Old 09-07-2017, 10:18 AM
jjsaustin jjsaustin is offline
Boat: 2015 x30
Are you trying to fill/drain using the touch screen or the manual switches?
The manual switches need to be in the middle position to be able to use the touch screen
Old 09-07-2017, 10:19 AM
Originally Posted by jjsaustin View Post
Check your ballast override switches.
What is a ballast override switch?
Old 09-07-2017, 10:21 AM
LKNtristar's Avatar
LKNtristar LKNtristar is offline
Boat: 1998 Mastercraft Maristar 200VRS
Had the same issue with my 06 X15 early this season. My ballast controls went out with a full load. Issue? Corroded wires on the inside of the ballast control module. Easy fix
ballast, x30
