Old 08-02-2015, 09:28 PM
barefootjoe barefootjoe is offline
Boat: 1980 stars n stripes Orig 351 pcm engine ++
90's Tristar into outboard-MC Prototype? Restoration
So, according to the guy who sold this to me in AZ this was a mastercraft prototype before he had it. I never confirmed this, but it does not have any holes for prop or rudder in the hull, no supports for an inboard engine. It appears to be a tristar conversion. When I purchased it the poorly welded jack box sitting on top of the swim step had failed and all that was left was some shredded outboard connections. I picked up a 1990 Yamaha 250 in Louisiana on my way back to PA.
Here is where I am at so far.
Had the jack plate re-welded and strengthened, and then I drilled and bolted it at all critical spots so that will not fail again.
Mounted the 250 on the back, installed the controls and took it for a test run.
It was very tail heavy and drove like a drift car/jet boat - (didn't turn until the prop overcame the turned hull.)
SO
I have welded up a frame between the stringers and installed two tracking fins in similar fashion to my ski centurion barefoot warrior outboard- roughly 2/5ths forward from the back.
Once the 3M sealer is cured I will be taking it for another test run, and bringing 5 gallon buckets of water to place in the nose. I plan on testing it with various weights in the front to find the optimum balance and then installing ballast tanks in the front for the future.
? Does anyone have suggestions on best method of filling/draining ballast tanks? I have several different tanks from old campers that I can use, just need to set up pumps or intakes or whatever.
? Anyone had a similar set up? I am wondering if this will allow me to turn and control well enough or if I will need to install an actual rudder like an inboard as well? (not sure how I would combine that with the hydrolic steering)
Questions? ask away, I will try to post pics later.
Who reads posts? I just look at the pictures.
Old 08-02-2015, 09:31 PM
aquaman's Avatar
aquaman aquaman is offline
Boat: 93 Barefoot 200 Yamaha 225F
I think pics are necessary on this one?
Old 08-02-2015, 10:46 PM
BrianM's Avatar
BrianM BrianM is offline
Boat: 1988 Prostar 190
^^^^^^^^This
Old 08-05-2015, 11:51 PM
lcgordon711 lcgordon711 is offline
Boat: 1994 American skier TBX
bump for pics
Old 08-06-2015, 12:31 AM
Old 08-06-2015, 11:38 PM
pbgbottle's Avatar
pbgbottle pbgbottle is offline
Boat: 1988 tristar 190
bump hhh
1988 mastercraft tristar (open bow).
ballast system, outboard, restoration, tristar
