  #21
Old 10-25-2017, 02:20 PM
You would only need a ballast resistor if you change back to points or a coil without a resistor.
I changed to an insulated post and have all my points parts in a box in the garage.
Custom wheel and tire packages
Rebuilding Holley Carbs $289
Rebuilt complete Holley Carbs $425
COSTOM DECALS - EMAIL FOR MORE INFO
Old 10-25-2017, 03:34 PM
Forgot to mention to set your timing to 10 BTDC.
Old 10-27-2017, 02:03 PM
Tmac in Folsom Tmac in Folsom is offline
Boat: MasterCraft, 1985 Stars & Stripes, 351, Powerslot
great; thank you...I've also read here that it's desirable to set the timing on the water, in-gear, at idle (5 mph lock-in)......do you concur? Then again; it's always possible that I misread the other timing post?
Old 10-27-2017, 02:43 PM
EricB EricB is offline
Boat: 77 S&S, 1983 S&& PS, and now a 98 Anniversary S&S LT1 PS
10 deg BTDC at 600 rpm. In gear if you want, in water out of gear, does not matter as long as it's close to 600 rpm. It's mechanical advance so rpms are more important than any other parameter.
Old 10-27-2017, 04:33 PM
thanks Eric.....so, I need to adjust the carb idle screw to attain 600 RPM first? Then se the timing?
Old 10-27-2017, 06:00 PM
Yes. That will work.
Old 10-27-2017, 10:03 PM
Set your idle speed to 600 RPMs in gear 675-700 RPMs in neutral.
Old 10-31-2017, 06:22 PM
Question: my original Pleasurecraft manual says to set timing at 6 deg BTDC; why are you guys recommending 10 deg BTDC?
Would it change the timing at all because I've replaced my old Prestolite "points" distributor with the new PerTronix Billet disti?
Old 10-31-2017, 06:53 PM
d2jp's Avatar
d2jp d2jp is offline
Boat: 1992 PS 205-351w,285HO
According to the good folks at SKIDIM:
"1986 - prior for a 351 PCM should be set at 6 degrees BTC @600 RPM. PCM 351's 1987 and later should be set at 10 degrees BTC."
I would go with what your manual says, assuming it's the correct manual for your year engine. It doesn't hurt to try anything between 6 and 10 degrees - and you should be able to find the sweet spot somewhere in there. After setting it, disconnect your throttle cable and increase your RPMs a touch, you should see the timing mark advance.
Jack
1992 ProSport 205
Smith Mountain Lake, VA
Old 11-01-2017, 07:26 PM
thank you Jack....I've got it set at a hair over 6 deg TDC right now and am anxious to get her out on the water and further fine tune if necessary. And yes; my PMC is the correct manual as I'm the original owner and have all the original paperwork including my $17,800 receipt from 1985...
