Old 11-30-2015, 08:11 PM
cloisel's Avatar
cloisel cloisel is offline
Boat: MC Sportstar 19, 2000, Predator
Calling on prop experts for a custom application
Hey guys,
I performed recently a larger retrofit of my former Sportstar into a 19ft V-drive due to various reasons I am gonna share in more details in a specific thread around the different steps I have been through this major project.....
However, in the meantime, and although some finish details (freeboard gelcoat, upholstery, plugged-in ballast tanks,etc.) will be ongoing during coming winter, I am begging for a prop advice from you experts.
Basically, my boat is a Sportstar hull (19ft version of Gen1 X-Star), and theretrofit included installation of a Hurth ZF 63 IV (1.55/1.56 gear ratio) to the original 310 HP Predator 350 TBI engine.
I performed successful mechanical water test using a 13.7x17 OJ stock prop, resulting in a running speed of 20 mph @ 1750 RPM. I feel the RPM are a bit low at similar speed compared to my previous dd configuration, also my program will now be 60% wakeboard / 30% wakesurf / 10% open water slalom ski.
Which prop setup would you guys recommend to optimize performance, considering above program and considering that wetted surface of my hull is slightly less than of a Gen1 X-Star?
Thanks for your input.
Clement
A French MC retrofitter
Old 11-30-2015, 08:38 PM
MC25's Avatar
MC25 MC25 is online now
Boat: 2016 X30, 85 S&S
Holy crap... Well done. I see Gen2 tabs?
-Aric
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
Old 11-30-2015, 08:44 PM
DooSPX's Avatar
DooSPX DooSPX is offline
Well Done for sure! Please call Eric from OJ Props and ask him. Give him the details of the boat and your goal.
His number is in my signature.
A.K.A. One of a kind mistake
2011 Best In Show- 1987-2000 class
Trying to keep slalom alive
Need a new prop to fit your needs? Call Eric from OJ PROPS 800-359-9730
Old 11-30-2015, 09:08 PM
ttu's Avatar
ttu ttu is offline
omg, what a nice transfer! I have not seen this done with the exception of someone doing a vdrive out of a old nautique 2001 model.
good job!
Old 11-30-2015, 09:10 PM
MLA MLA is offline
Boat: pontoon
What is the WOT rpm and how are you going to use the boat? The ACME 1631 4 blad will work well with the 1.55:1 gear and is a lower pitch then that 17 OJ but about the same dia. The 1431 is 13.5 x 14.25. Should do well for general use, but may be a little high on the RPM for barefooting.
Old 11-30-2015, 09:44 PM
scott023's Avatar
scott023 scott023 is offline
Boat: 2008 X45 Switch L18
I'm impressed. That looks like a heck of a project. I'd love to see more pics.
Old 11-30-2015, 09:52 PM
dvsone79's Avatar
dvsone79 dvsone79 is offline
Boat: '99 205v
That looks awesome! What amount of ballast do you plan on using?
Old 11-30-2015, 10:37 PM
Shaun R's Avatar
Shaun R Shaun R is offline
Boat: 2011 X25
Guessing you have the 1 1/8" shaft? I run the 14x20 4 blade off a Gen1 Xstar and it works well with mine. Only run about 800lbs of ballast with three in the boat, but it had no issues getting out of the hole. Prop is common with Malibu as well as easy to find used in the states.
Nice work on the teak platform. Curious how the surf tabs work on such a small hull.
Old 12-01-2015, 01:27 AM
lees23 lees23 is offline
Boat: 2017 22 VLX
From the OP:
Old 12-01-2015, 02:07 AM
I am truly amazed what someone can do with these boats... looking forward to read more.
