Old 08-19-2016, 03:18 AM
phil_edgecumbe phil_edgecumbe is offline
Boat: Prostar 205 - 1997
Help with bearings and seals
I have a 1997 Mastercraft Trailer and want to buy a spare set of wheel bearings and seals.
The brakes are 10inch drums made by UFP with hydraulic actuators. The part number on the hub is HD-1077-10.
Can someone provide me with bearing and seal part numbers and recommend an online supplier that will ship to Australia?
Thanks in advance.
Old 08-19-2016, 03:30 AM
ac505 ac505 is offline
Boat: ...
Best option would be to strip one hub down and get the p/n's for the bearing, cup and seal. Bearings as a general rule are pretty easy to come by, so you will be able to source locally.
Old 08-19-2016, 03:53 AM
Boat: 1998 Maristar 200VRS
You could refer to the attached, but I think you'll end up following ac505's suggestion.TBAxleMaint.PDF
Old 08-19-2016, 04:33 AM
Thanks guys. I managed to get the part number from the outer bearing but couldn't remove the grease seal without destroying it to get to the inner bearing. Guess I'll have to remove the seal, find out the bearing part numbers and order some new ones.
Old 08-19-2016, 08:02 AM
Legolamb Legolamb is offline
Boat: 1996 Prostar 190, LT1
Call Waymire Distributing in Indianapolis, IN to see if they ship to you. They definitely have all the bearings and double lip marine seals you need for UFP products.
800-434-4824
http://www.waymires.net/
Old 08-19-2016, 05:22 PM
willg willg is offline
Boat: 02 X-Star
Bearings are relatively standard parts, you might be able to find them locally in Australia.
Old 08-20-2016, 12:19 AM
if you know the outer bearing number, you can match it up with the tables on page 4 and 5 of the PDF I posted (double-click on TBAxleMaint.pdf in post #3) and figure out both the seal number as well as the inner bearing/cup numbers.
Old 08-20-2016, 10:30 AM
this is most likely the size but verify - these are for a 1996
Spindle size OD= 1 3/8" x 1 1/16"
Inner bearing L68149, inner race L68110 (koyo) or L68111
Outer bearing L44649R, outer race L44610 (koyo)
(UFP kit 07007U0)
Seal size is 1.688" x 2.328" x 1/2" wide. Should use a double lip seal, UFP 07027U.
Old 08-20-2016, 11:33 AM
JBrew JBrew is offline
Boat: 2017 XT23
So many trailer issues as of late! I think mike205 is correct on spindle and bearings. My seal was:
ID = 1.68"
OD = 2.56"
