Old 05-16-2018, 02:02 PM
D2Dominator D2Dominator is offline
Boat: 2002 X-Star, Indmar
How high do you Rev your Engine?
Good morning All,
May seem like a random question, but keep in mind that I come from the world of outboards.
Anyhow, I've had my 2002 X-Star for a year now and have yet to open her up. We typically wakeboard or cruise around with the family of young kids. In the outboard world, we often ran full throttle for periods of time but I'm scared to do it to an inboard for some reason.
So I ask... Am I being a wuss? I've never hit the rev limiter, and I don't think i've ever exceeded 35mph.
Can the 310 Predator run at high RPM's for long periods of time?
Thank you in advance,
D2
2002 X-Star Indmar 5.7 Vortec Predator
Old 05-16-2018, 02:09 PM
lakedrum03's Avatar
lakedrum03 lakedrum03 is offline
Boat: 2003 X-Series MCX
At its heart, these are Chevy 350s, which have a long history of running hard and taking the abuse.
That begin said: these are ski boats built for a purpose, it is not to go fast. Can they go relatively fast for a boat of their size? Yes, most definitely.
I use the following rules of thumb: use the boat for its purpose at whatever speed and RPM when skiing. When not skiing, there is absolutely no reason to take the motor over 3k RPM. Mine runs great right below 3k, just enough bow rise to take the hits and still has a nice cruising speed. We have the same hull. When not cruising and not skiing, there is no reason to be above idle.
Those are my $0.02, but to me they are worth at least $0.04.
Being on a boat that's moving through the water, it's so clear. Everything falls into place in terms of what's important and what's not. - James Taylor
Old 05-16-2018, 02:20 PM
LDA6339 LDA6339 is offline
Boat: 2016 Mastercraft X-30 6.0L
At first glance I took rev to mean running up RPM's in neutral, which I definitely do not do, unless I'm putting it at 1,000 RPM to keep alternator spinning when using ballast pumps.
I cant remember the last time I was above 28 mph or 4k RPM, so not super high.
Old 05-16-2018, 02:28 PM
d2jp's Avatar
d2jp d2jp is offline
Boat: 1992 PS 205-351w,285HO
I'm in the same boat as the OP, pun intended. Typically we are pulling skiers and boarders and usually never more than 32mph, and typically below that. Cruising RPMs are 1800-2400ish. My father-in-law once asked me: "how fast will she run" and he looked stunned when I said "I have no idea".
Jack
1992 ProSport 205
Smith Mountain Lake, VA
Old 05-16-2018, 02:37 PM
trunderw trunderw is offline
Boat: 2008 X-14 MCX w/Powerslot
About 5300 rpms for my motor. Prop should help prevent exceeding top rpm
boats rock, but don't rock the boat
Old 05-16-2018, 02:42 PM
james_shoemaker james_shoemaker is offline
Boat: Mastercraft 1982 351 Powerslot Stars and Stripes
Same here on unknown top speed, I haven't had a reason to take her over 36mph as that's the max speed through the slalom course anyway. The "I don't know" answer confuses them until I explain what the boat is designed for and best at, then I take them out for a hole shot and when they slide off the observer's seat onto the floor they realize the truth.
James
Old 05-16-2018, 02:45 PM
lakedrum03's Avatar
James
hahahah. Yes!
Old 05-16-2018, 03:48 PM
88 PS190 88 PS190 is offline
I rarely go faster than about 38 mph, with out trim control and a V-Hull I just don't find it very appealing and if you get a few decent waves they'll really make it porpoise.
Old 05-16-2018, 04:12 PM
Makes total sense... I guess in a world where we no longer have to cover a lot of ground in a little time, there is no sense in maxing it out!
I suppose if I need to outrun a storm I can open her up a little bit...
Old 05-16-2018, 04:41 PM
JohnnyB's Avatar
JohnnyB JohnnyB is offline
Boat: 2004 Prostar 190
Iirc, the Predator engine is rated for 4400 to 4800 RPM max...check your manual.
I believe my prop holds mine to 4600 which gets me 42mph....run pretty constantly 4400 when we're footing. My boat gets used for footin 50% of the time, slalom 40% of the time (30mph-36mph) and cruising 10%
Sent from my SM-G920R6 using Tapatalk
2004 Prostar 197, ACME 843
