Old 05-07-2013, 08:32 PM
ohiojohn's Avatar
ohiojohn ohiojohn is offline
Boat: 2009 X-14
X14 Wakesurfing
Need some advice. Bought a 2009 x14 and would like to try wakesurfing behind it. Any advice on the fill of the factory ballast and the extra sacs I will need.
Thanks
John
Old 05-07-2013, 08:36 PM
MC25's Avatar
MC25 MC25 is online now
Boat: 2016 X30, 85 S&S
http://www.mastercraft.com/teamtalk/...ad.php?t=31487
-Aric
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
Old 05-07-2013, 08:49 PM
ohiojohn's Avatar
Boat: 2009 X-14
Thank you for the quick response.
John
Old 05-08-2013, 04:03 PM
jason95gt jason95gt is offline
Boat: NA
Fill up the center tank and rear of the side you are surfing on, then add a fatsac seat base ontop of the seat behind the driver (goofy rider) or on the floor next to the motor box (regular foot). It surfs, the pocket is just close to the platform. Another thing to do is modify the platform or pin it up.
Old 05-08-2013, 05:57 PM
ohiojohn's Avatar
Boat: 2009 X-14
Jason,
Thanks for the tip. How big of a fatsac on the seat should I add ?
John
Old 05-08-2013, 06:16 PM
JohnE's Avatar
JohnE JohnE is offline
Boat: XT22
When I had my X14 Mike Siepel from Barefoot International recommended a pair of 750's (that won't fill all the way) on each side rear. Port on floor next to motorbox, starboard on wrap around seat. And another 750 (that still won't fill all the way due to space constraint) in bow. My dealer/ friend at the time said that is "way too much for that boat". So it left me confused. Then life changes never allowed me to really spend the time to experiment.
Personally I'd start with a 400 on the side you surf as Jason suggested and go from there.
Old 05-09-2013, 07:41 AM
madcityskier's Avatar
When you want more than the 400, you have to buy bigger. If you get the 750 you don't have to fill it completely. Just my 2, others may disagree.
Old 05-09-2013, 08:39 AM
mzimme's Avatar
mzimme mzimme is offline
Boat: 2006 20' Vdrive
Remember, weight in the rear makes the wave taller. Weight in the bow makes the wave longer (and hence makes for a larger "sweet spot"). Try loading up the rear with ballast, and tell your friends to take a seat in the bow. With a bunch of weight in the bow, be sure to turn away from the side you're surfing on when the rider falls, and power the bow up when you crash through the waves after you turn around to keep water from coming over the bow.
-Mike
Old 05-09-2013, 09:22 AM
JohnE's Avatar
Boat: XT22
That was what I was trying to say in my post based no BI's recommendation
Old 05-09-2013, 09:48 PM
ohiojohn's Avatar
Boat: 2009 X-14
Thanks for all the tips. I found a 455lb sac I am going to start with and see what happens.
John
