Go Back   TeamTalk > Classifieds Buy/Sell > For Sale: Parts & Accessories
Old 09-29-2018, 08:32 PM
paintpollz's Avatar
paintpollz paintpollz is offline
Boat: 2002 Prostar 197
WTB prop puller
I need to pull the 4 blade prop on my 197. Being cheap and don't want to pay $100 for a puller that I'm going to use once. Also, I don't get the 3 blade prop puller 4 blade prop puller, don't they both grab the back of the prop and tighten it against the shaft? Not sure what the differences would be....
Even better, who is in DFW that could lend me one for 5 minutes!!!! PM me! Thanks , Kevin.
Kevin
Old 09-30-2018, 12:29 PM
JohnE's Avatar
JohnE JohnE is offline
Boat: XT22
You'll only use it once....until you ding it and need it again. I bought one years ago and dropping $100 didn't bother me much.
Old 09-30-2018, 02:54 PM
Spending $100 to have the proper tool to remove a $400 on a boat worth many thousands of dollars seems like money well spent to me.
Old 09-30-2018, 03:21 PM
Dont be that cheap... more than worth the cost of a fuel tank of gas... own a boat... own base set of proper tools... IMO... dont be that guy
Old 09-30-2018, 03:26 PM
MLA MLA is offline
Boat: pontoon
The ACME c-clamp puller is for 3,4 and 5 blade props. However, there is a different puller based on the prop shaft size. Namely, the 1.25" shafts. The harmonic pullers are based on the thread size/pitch of the shaft.
Old 09-30-2018, 06:55 PM
roadster02 roadster02 is offline
Boat: 1980 Glastron Carlson CVX-16 Deluxe w 1981 Evinrude 140
Use a hammer.
Old 10-01-2018, 07:45 PM
paintpollz's Avatar
Originally Posted by roadster02 View Post
Use a hammer.
I tried! Along with the ghetto puller device i was using. That thing is on there tight, even though I had it off the boat once this year.
Point taken by everyone, not to be "that guy"
Kevin
Old 10-01-2018, 07:55 PM
Try a "dead blow" hammer and a block of wood.
Old 10-02-2018, 12:07 AM
TX_Wake's Avatar
TX_Wake TX_Wake is offline
Boat: 2001 Mastercraft X-10
I used the largest puller of this 3 puller set from Harbor freight.... was about $27? Barely fit, but worked for me.
Old 10-02-2018, 08:33 AM
JohnE's Avatar
Boat: XT22
I've had to use a torch to heat up the prop to get it off. Leave the prop nut on by a few threads, put tension on the puller, and heat the prop. When it goes, it pops. You might try heating it then tapping with a dead blow hammer or a block of wood/ hammer
