Old 07-28-2016, 10:45 AM
Dino Don's Avatar
Dino Don Dino Don is offline
Boat: mastercraft 190 1987 351 Indmar
Says leaded fuel on the 76 engine---wonder if the seats shouldn't be replaced with harden seats?
Old 07-28-2016, 11:02 AM
keith3613 keith3613 is offline
I use lead additive on my 1984.
Old 07-28-2016, 11:23 AM
Originally Posted by 03 35th Anniversary View Post
Damn Know It All......
$250 FULL STARS & STRIPES DECAL KITS
$200 FULL DECAL KITS 1987-1989
COSTOM DECALS AND OTHER YEARS AVAILABLE
Old 07-28-2016, 11:27 AM
paco_06's Avatar
paco_06 paco_06 is offline
Boat: 1993 prostar 205 previous 85 S&S
Originally Posted by waterlogged882 View Post
No. I have never used anything other than what is at the pumps - 87. The Windsor is tough and adaptive to hard work and cheap gas....I took that photo a day or so ago....
Comment of the week!!! I am also a Windsor fan.
Old 07-28-2016, 11:43 AM
Originally Posted by EGRAY View Post
I plan on checking the timing on my (351) 93 205 this weekend. Should it be 10 @ 1000 rpms when in gear or when in neutral @ 650 rpms??? This will be the first time I have checked it since I had a new long block installed a year ago.. Also note that I'm at 310 HP with the new block. Only reason I'm checking is because I get a random back fire through the carb sometimes when under load around 3000- 3500 rpms... I have new plug wires, plugs and new cap and rotor are going on Friday night when I get to the lake house. Sorry for the hijack on the tread JayBrown....
Thanks
Eric
Set timing in neutral at idle. This should be approx. 800-850 RPMs.
If you are backfiring through the carb under load, you likely have a problem with your ignition system. Start by checking voltage at the coil + with key on/engine off and while running. Voltage reading should be same as battery voltage, or at least very close. If you are good there, you will find your problem within the ignition secondary components: Distributor (including cap & rotor), plug wires spark plugs. You may have a worn bushing in your distributor.
Old 07-28-2016, 11:51 AM
EGRAY EGRAY is offline
Boat: 1993 205 prostar
Thanks a bunch!!! Can't wait to get on the lake!!
Eric
Old 07-28-2016, 12:07 PM
Eric
Good luck Eric. Keep us posted on your progress.
Old 08-01-2016, 11:40 AM
New cap and rotor did the trick!!! She is running like a champ!!
Thanks for the help!!
E
Old 08-01-2016, 12:12 PM
Perfect outcome!
